Polyurethane suspension bushings
As for wanting an example, I was talking about DRIVING example. Say....in a parking lot turn a HARD corner pushing through it with maximum acceleration -- without losing it sideways. You know...at 25mph, 30, 40, whatever. FWIW, I was sufficiently impressed by the Newman's video. And, if I hadn't (yet) gone to poly, I'd give more serious thought to heim trailings arms. Control arms too -- though I'd prefer press-in bushings [for those] that would do the same thing on the control arms.
Note: Since I'm getting tires/alignment next week, I wanted to "vigorously" counterpoint this issue. With any serious desire to redo the back, I'd hold off on any alignment.
If you have old rubber bushings that need to be replaced, there is no good reason to use hard poly bushings when you can use SuperPro that are not way more money and are actually easier to install. Rod-end links are probably overkill unless you're using the car in a competition environment.
Not sure why Poly is harder? Most of installation (for me) was pressing the old rubber out, cleaning the arms THOROUGHLY, then polishing the arms. I can't remember if the were 2-part (like superpro's vid suggests). If they are, it's just lube and place in rod end before reinstalling the rods. If they're 1-pc, I don't remember any additional trouble pressing them back in. All I can remember is using 2-3 ratchet sockets (depending on rod end/bushing size) as shown in the superpro video.
I would have thought snap oversteer required acceleration vs just braking/turning? You know...something to shift the weight back onto the rear. Otherwise hard braking/turning is down mostly with the front tires, right? Maybe you're saying poly can cause the rear to "spring" out and around during an emergency brake/turn? Even that seems counter-intuitive since the weight isn't shifting down (in the rear) then back up. I would have guessed it to happen coming OUT of a HARD corner then accelerating. (Similar to hitting the gas and going around a car in front of you)
All this said, I was 100% sold on heim link's value watching the Newman's video.
In my tire thread, you suggested 34/30 (or 33/29) PSI might be a good combo for a street car -- if not mine specifically? I'm guessing it can smooth the ride but I don't think you were suggesting pressure as a means to alter steering? Maybe so? I'm curious if fatter rear tires (315s) -- combined with lower pressure -- would essentially offset all/most of the "snap oversteer potential" for owners running poly bushings?
Even without fat rear tires, maybe owners running poly should seriously consider lower rear tire pressure?
[/quote]In my tire thread, you suggested 34/30 (or 33/29) PSI might be a good combo for a street car -- if not mine specifically? I'm guessing it can smooth the ride but I don't think you were suggesting pressure as a means to alter steering? Maybe so? [/quote]
I probably suggested that for your particular setup, which I believe was involving 315 rear tires. You would run less pressure in a 315/35/17 vs a 275/40/17, all else being equal.
If it sounded like I was implying the problem would be "gone", I misspoke. For other readers, I can't say I regret the choice of poly. If you're needing a lower cost bushing replacement -- especially for a street-driven car -- I wouldn't shy away from it. I've had mine for 5yrs and haven't been "surprised". With a new set of Michelins, response has gone way up -- as has my ability to run more pressure COMFORTABLY. In itself, I feel there's been a great difference in tire choice -- than my conversion to poly. I tried making some fairly aggressive swerves today -- just to "test". You must REALLY need to so something drastic for poly to be "dangerous" -- as implied. Because, I don't see the problem. With poly bushings and new Michelins, I'd just say mine feels damn "tight". And, I like it. (Who knows, tire pressure might also mean more than bushing choice?)
Given the choice for a redo and with an extra grand lying around, I'd be all over heim links. Superpro's are probably nice but total, free articulartion does sound the best. All that said, until poly is deemed as unsafe as the Pinto, I can't tell others NOT to try it. After all, there has to be a TON of C4's needing new bushings where they don't want to spend a buttload for a bushing upgrade.
