Polyurethane suspension bushings
Also, I wouldn't think there'd be THAT much "out-of-plane" articulation (after see how it all "works" via bushing change). Plus, the graphite-impregnated bushings should allow some "slide" if not enough flex???
If you want further evidence, not that Global West and Van Steel make Delrin bushings for C4 front links, but they won't make them for the rear. Guess why? Delrin is even harder than hard poly bushings, and they know how badly it would bind.
As for how much movement off axis there is, if one trailing arm is 12" and it sits parallel to ground with the car at resting ride height, and the camber rod is perfectly on its bushing axis in that condition; then compressing the suspension 3" will pull the end of the camber rod 0.4" off axis. If the camber rod is 24", then both trailing arms will also be getting pulled 0.2" off their bushing axis. That's no big deal with rubber bushings, but it is with hard poly. Each link will require significant force to pull it that far off axis (there are two bushings exerting force for each link), and then you have to add up those forces from six links. So we're adding up the force of 12 poly bushings being pulled that far off axis. It's a rising-rate force that is added to the roll resistance provided by the spring and sway bar. And the softer the springs and swaybars (again, going back to the "average" driver in a softer car, even with C4s), the bigger an effect it will have on the handling.
With that said, a complete C4 Corvette set is $325.00 to $350.00
https://www.corvettepartscenter.com/collections/c4/products/late-1988-1996-corvette-suspension-bushing-kit
https://www.corvettepartscenter.com/collections/c4/products/1984-mid-1988-corvette-suspension-bushing-kit
There is no significant "slide" along the bushing axis in a properly installed poly bushing: the bolt-nut should be torqued down so the two frame tabs capture the inside sleeve and keep it from turning, and they pretty closely capture the poly also (just not quite). If they could like you say, then the suspension geometry would change.
It's also not clear how problematic worn rubber might be -- in comparison to new poly? I'm not challenging your premise about firmer suspension bushing -- just that the problem has been "measured"...and for all options.
What are these SuperPro bushings made of? Sounded like a poly (blend?) to me....when I read a blurb off their website.
EDIT: Also, it's been too long since my reading on rear end suspension...Don't the use of 2 trailing arms help to keep up/down articulation more "linear"?
NOTE: I assume you're saying the rear-end "loads up" under turning forces and springs back HARDER than with rubber -- kind of "shooting" the rear around a turn. Since poly is firmer than rubber....or at least presumably is. The result is "snap oversteer".
Plus it is the rest of the old car guys that spend money on their machines, do you notice how many ratty C4 Corvettes AND later model C3's for that matter are on the road ? Around NE Ohio there are lots of beaters driving around.
Also handling. The solid rear axle cars get their suspensions really tightened up with polyurethane.
I did a quick search on poly vs rubber bushings oversteer and didn't find much. WAY more websites tout the use of poly saying mild increases in vibration/feel were offset by improved geometry since components stay more in their "plane". Like this one...
https://dsportmag.com/the-tech/quick...t-to-the-test/
Looks like similar control arms on the Miata...though you can't see in front of the suspension (trailing arms or ???)
If I understand correctly the main point of concern is where the control arms attach to the rear diff carrier?
EDIT: This sight provides some counterpoint (to the one I linked 3 lines above...
https://www.iwsti.com/threads/bushin...ethane.206293/
Anyway, the regular poly bushing makers are vying for being able to advertise the least flex possible. Just look at their ad copy touting why their bushings are so much better than stock rubber. That's why they don't look for poly formulations with more flex. They've spent many decades convincing consumers that bushing flex is universally bad. I've got news for you: they don't care how your car handles. They care about convincing people who don't understand suspension dynamics that stock rubber bushings are terrible and they will have an F1 car if they just put hard bushings everywhere. And since 99% of their customers never really drive their cars hard, they don't know the difference. You see the same thing with suspension companies that encourage car owners to replace their "flimsy" stamped U-channel control arms with boxed or tubular ones, and the exact same thing happens: bind, because the torsional flexure of the stock parts was designed in on purpose to prevent bind. The vast majority of aftermarket companies have no idea what they're talking about and/or have no intention of making cars handle betters: they are marketers of crap, pure and simple. The Banski and After Dark Speed types of companies are few and far between.
Heim joints allow rotation in any axis around a single point. They have no bind in any plane as long as you don't try to exceed their limits of travel. They are the best bushing replacement for the rear of a C4 in terms of performance, but are definitely overkill for street driving.
Most websites have no idea what they're talking about. This one talks about poly bushings reducing the roll angles of a Miata. That tells you they are stupid. You should never pay any attention to their tech articles, because they don't understand this stuff. Also, the Miata's rear suspension may not require its links to move in multiple axes. I'd have to study it more. I know its front doesn't, and neither does the C4's. Poly bushings are fine up there. The C5 rear suspension has upper and lower A-arms and also is probably fine with poly bushings.
The control arms really only move up and down on the front. I suppose that there would could be some out of plane movement on rear control arms (coil spring cars) but when the old black rubber got hard, there was no movement other than around the bolt.
When I torched the bushings out of the front a-arms of the '65 I did the bushings were hard hard hard.
Then you look at these. The articulation is coming from multiple pivot points that allow movement. Any radial deflection in the bushings is secondary and can cause a lot of stacked up slop.
https://www.drivingline.com/articles...tion-got-flex/
https://monroe.com.au/trade-corner/t...ear-suspension
The entire car "works" on all four corners, limiting how much deflection is at the bushings.
I agree, when new, that rubber bushings absorb and allow suspension pieces to move before the rest of the car starts moving and relieving radial twist through other suspension pieces moving. The entire car "works". If you have a lift under the right rear tire, the left front starts to squat, relieving radial twist in the suspension components/bushings themselves replacing it with mechanical motion on all four corners.
I found out about rubber bushings 43 years ago when I started into the Corvette world. When I worked in a defense shop, the military used lots of Teflon components. I saved bar ends. I machined bushings for the shocks and sway bars on the '65 I had. The rest of the suspension was new, I stripped it to the frame and rebuilt the suspension back. With the addition of the Teflon the suspension was quick and tight. The guy I sold the car to almost wrecked it going home it was so quick. He was an experienced Corvette guy, but experienced with a suspension that just didn't react.
The Del-alum (and other solid) bushings, while imparting a harsh ride don't have the tolerance stack up from rubber squishing before the rest of the car moves. I would surmise that this is what cracks polyurethane. I have had poly shock bushings crack on my trucks through the years. It starts compressing before the shock internals start to move. Over and over and over until it cracks.
Black rubber compresses before the rest of the suspension moves, over and over and over, until as it ages and gets harder, and then starts wallowing out, or becoming so bound up, the suspension just doesn't work. The '65 was a combination. Some of the front control arm bushings were wallowed out, some were just twisting the sleeve inside the rubber.
This is why I like the pin-top shock bushings that I got from Banski so much. It is the shock internals moving, not the bushing compressing and then the shock internals. I will say though, there is some radial movement at the top of the shock. This is relieved by the top of the bushing being machined spherically, with the "washer" on top having a corresponding internal cut, that forms a ball and socket.
Of course, that's when Banski still carried them. Maybe the ends WERE $20-25 each at Rod End Supply? I remember they had two types....One might have come with zerts?
If they were [some-how] sealed, I probably would have gone for it.
I wouldn't be surprised if all new ends for trailing arms > $200. At least SOME ONE still sells trailing arms and control arms with heim joints.
I just didn't know poly was "that bad". I had the ***-end kick-out one time. Almost clipped another car. ALMOST - BUT NOT QUITE! That's the only time since 1999. And, I still had the OEM rubber. At least it wasn't as bad as a co-worker I let drive the car when "new". He got up to an intersection, floored it -- while turning -- and did a 180. Immediately got out of the car and walked back to work. I had to run and get it! LOL Some people can't drive worth a crap.
https://www.ridetech.com/new-corvett...-even-tighter/
https://www.ridetech.com/product/198...trailing-arms/
https://www.ridetech.com/product/198...ower_11567295/
https://www.corvettecentral.com/c4-8...-arm/?count=45
https://www.vansteel.com/index.cfm?f...&subgroup=1906
Rubber boots for rod ends are available on Amazon (other places also) really inexpensively. The installation tool for the rubber boots is inexpensive and also available.
