vacuum valve ?
Old Jun 14, 2022 | 11:31 AM
Eduardo L98 1991's Avatar
Eduardo L98 1991
Default vacuum valve ?
what is the name of this device ?. vacuum valve
installing superram, I dont have egr, Im removing siamese runners but I realize tha this vacuum device is only connected to harness and vacuum to body throttle
can I delete this ?, do I need to modify eprom ?
thanks in advance
Old Jun 14, 2022 | 11:36 AM
WVZR-1's Avatar
WVZR-1
There should be some identifying character on the device - maybe a DRxxx with the xxx being numbers likely. Should be very visible!
Old Jun 14, 2022 | 11:45 AM
Eduardo L98 1991
dr 195
0110
TPI EGR CONTROL VALVE RELAY SOLENOID 1997195 DR195 86-91
thanks, down a lot of dirt
then I only need to block the Body throttle vaccum line ?
chip is already modified to delete de egr
To vacuum valve ?
