brake hose collapsed?
I was bleeding the brakes yesterday and my vacuum bleeder got fluid out of all calipers. However, the RR caliper was barely giving up fluid. I pulled the nipple and blasted it with brake cleaner. It didn't get much better, but I eventually got enough bad fluid out to see fresh. The bad fluid was not too terrible, an amber color.
The brake pads appear to be wearing even. The car seemed to stop ok, but I honestly only drove it 15 miles since buying. I am thinking, having read such on here, that the hose might be collapsed? It is not cracked or old looking. Car has 67k.
On the same token, The clutch slave cylinder was hardly giving up fluid, but I got it to flow clean as well. This fluid was like old motor oil in color.
I used a turkey baster to pull old fluid from the master cylinders and filled with fresh fluid before starting.
I ran out of time and was unable to check the brake pedal feel after the bleed. It was seemingly normal before so I have no reason to believe it is any different.
I need to pull the disk to see why the parking brake isn't working. There is no star wheel that I can see through the little holes. I can flush the caliper with it off the car.
I plan on getting braided lines eventually. Probably with rebuilt calipers when I replace the pads once they are worn out.
like the bleeder plug inspection idea.
if you remove the hose from the caliper, grab a yogurt container and put an inch of fluid in it. your old brake fluid id fine.
place the disconnected brake line below the fluid level and have a friend pump the pedal slowly-ish. you may have a blockage in your line, and you may pump it out. careful u might get a spray of fluid if pressure builds and releases when blockage releases.
If that happens, a very good plan is to replace rubber lines on all 4 corners and id expect your calipers to now bleed normally.
dont be surprised if you have a sticking caliper. These can easily be cleaned up, you can youtube vids that show you how to safely remove the caliper piston and put it back. cheers.
