where is jack? I just wanted to use it to bleed brakes i assume it would get car off ground far enough to bleed brakes.
It should be above the spare tire, if you're car is
un-raped behind driver's seat a lug wrench is wing nutted to floor. Take that and back off the spare tire mount be carefull not to drop upper Tee to lower notch with enough slack in bolt lift cover over lower Tee tire will fall out. The jack should be spring clipped to spare
