Coolant smell
Old Jun 27, 2022 | 07:51 AM
Incorvettei's Avatar
Incorvettei
Default Coolant smell
Hey guys
my 86 Vette just started smelling like coolant after the 195 degree thermostat opens. I see no leaks, nothing on the garage floor and not using a drop of coolant or oil or anything. I did the throttle body bypass, no leaks there either.
It runs down the highway between 180-190 degrees and around town between 195-210 degrees.
I am a total loss, anyone have any ideas?
Thank you
Old Jun 27, 2022 | 08:00 AM
Red86Z51's Avatar
Red86Z51
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (stock) 2019
Is your car a Z51? If so, you can check the additional connections for a small seep. It doesn't take much coolant to seep to give you that smell when the car is hot. Also, an old radiator cap that's not sealing at 100% can emit that smell when hot without you losing coolant. Gotta do the "sniff" test when hot to check that.
Old Jun 27, 2022 | 08:04 AM
Red86Z51's Avatar
Red86Z51
Oh, and also check your heater core shut off valve too. It can seep/weep and eventually drip a small drop onto the frame, enough to give that smell without leaving coolant on the floor. Do a sniff test and visual on that too when hot.
Old Jun 27, 2022 | 09:12 AM
Incorvettei
Red 86, yes it is a Z51. Thanks for the advice, I will check what you have pointed out
Old Jun 27, 2022 | 09:53 PM
Ark--C4's Avatar
Ark--C4
........and the heater core--is the carpet wet?
Old Jun 28, 2022 | 05:53 AM
Incorvettei
No Ark. there is nothing wet inside
Old Jun 28, 2022 | 01:22 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I vote small heater core leak. Is there any film appearing on the inside of the windshield?
Old Jun 28, 2022 | 07:02 PM
Incorvettei
Jud, no there is no film on the windshield at all.
Old Jun 28, 2022 | 07:15 PM
Jud Chapin's Avatar
Jud Chapin
I would suggest doing a pressure test on the cooling system.
Old Jun 29, 2022 | 07:32 AM
Incorvettei
Thanks Jud. I appreciate your input
To Coolant smell
