Fuel Injection Control
If you do decide to ditch the factory EFI, don't throw the ECM, MAF, or burn off module away. They are all one year parts, specific to the 85. You shouldn't have any trouble selling them.
For the dash: the factory speedometer, coolant temperature, oil pressure, and oil temperature senders stay wired as-is. You will use the factory senders to run the dash. My tach feed comes from the Holley EFI.
I am not familiar with the Megasquirt but the wiring will be similar with any aftermarket EFI.
I only had to add two sensors when i switched to the Holley system. It has another coolant temperature sender of its own and came with a new MAP sender. It also controls the factory IAC motor, which controls idle RPM. (Yours has one, it's on the bottom of the throttle body.)
Are you planning on running the factory HEI ignition or something aftermarket? I believe you can keep the factory HEI if you aren't planning on making it a sequential EFI system.
The switch to an aftermarket EFI system can be a little tedious (wiring it takes time and attention to detail) but isn't too terribly difficult. If you run in to any issues with wiring it, I'm willing to help as best I can.
If I remember correctly, the burn off module is behind the "bread box" in the 85.
The only sensor you'll need to change out will be the MAF, I don't believe megasquirt will work with a hot wire MAF. You can either go to a MAP sensor or put in a different MAF.
I agree, the Terminator X would be a better route. Looks like the 550-936 might be a good fit and cheaper. ($1249)
I haven't used the Terminator X software but have used the HP/Dominator software and it is pretty user friendly.
The TermX is a pretty good value. I went with the HP in my 85 (turbocharged) but would have gone with the TermX Max for my 99 Suburban instead of HPTuners if it had been released back when I did upgrades to the truck.
A holley with harness is superior for beginners, easier to make fewer mistakes. But still there are plenty of mistakes to make. I find many people tying their harness wires together with starter wires and battery feed cables for other devices. You have to really know what you are doing mechanically and read the manual if you are new especially.
The problem is, if you have not already done it at least three or four complete installations Inside various kinds of cars, you may make a series of avoidable mistakes which may be difficult to overcome without guidance. For example harness shielding and ECU grounding and power supply proximity. Wires carrying large currents produce magnetic fields which interfere with nearby wires. So a starter cable for example near the ECU or ECU harness is going to likely scramble several sensitive signals in the ECU- and the car might still try to start anyways, possibly causing damage to the engine. If very high compression an improper early timing event at cranking can be disastrous to bearings for example, it may create extremely high compression PSI While there is no oil pressure during cranking. Another thing common is the crank trigger signal issues abound, it seems like every other vehicle that the customer does the install themselves and then asks me to tune has some issue with the crank trigger when using aftermarket computers especially. Another thing is that when the starter disengages the collapsing magnetic field causes a voltage spike. Even injectors do it. So proper use of diodes and power feed fabrication is a part of setting up to run right which can influence tuning and issues with burning up electronics over time.
Megasquirt is also a very good option. But I would avoid the Microsquirt unless you are using it for transmission control for a 4l60e or a 4l80e. If I'm not mistaken the Megasquirt has more inputs and outputs. I know the Microsquirt is batch fire for fuel and I don't think the Megasquirt is.
One issue that some people don't consider with any aftermarket EFI is will it pass inspection in your state with it. Here in PA they won't unless you have classic or antique plates.
https://www.corvetteforum.com/forums...-1985-z51.html
Post #9 mechanical checkup
https://www.corvetteforum.com/forums...post1605334191
I would follow that up with a fully engine cleaning, degreasing,
Post #39 engine wash
https://www.thirdgen.org/forums/tech...ml#post6470834
With clean engine and mechanically sound, most issues will have evaporated leaving just wires, computer, fuses, sensors.
Then, you get hands on with the OEM ecu and do whatever you can with that. Learn it the best you can. Read online manuals from Megasquirt, AEM, Accel, Haltech, etc... Read every book and use the knowledge to learn your limitations. Break it if you have to.
Also helps to brush up on mechanical advance and carb tuning.
And learn a little computer programming coding language.
Then you are ready for aftermarket EFI.
Depending on which megasquirt version you run you can have something equivalent to whats already in the car vs basically a modern EFI system. MS1 isn't much better than whats in the car already, MS3 has oodles and oodles of options. I went with MS2 on my 280z when I got sick of dealing with the ancient "computer" in it and it worked great.
Megasquirt can run batch fire or seq, for seq you just need some sort of way to measure the crank. There are MANY crank wheels for a 350 that mount on the balancer and then you can just rig up some sort of sensor. Once you've got that it also isn't very hard to go to a wasted spark or similar system and get more power.
NOBODY is trying to insult you, we are trying to help you avoid MORE costly mistakes. If you cannot find these components and use a scanner with factory service manual to see whats going on, and you just use an autozone code reader to replace parts when it says it has a code;YOU WILL NOT FIX ANYTHING RIGHT! Remove your feelings and ego from the situation, follow the link i posted a few replys up and start troubleshooting the car. It doesnt need additional timing when it is cold, it does not need fueling changes. It needs to have the wiring, mechanical, and vacuum lines of the egr and est system sorted out. it needs to have all codes cleared and actually fixed! Once you do that it will probably start, run, and drive just fine. If you cant find the info i am suggesting you have no business messing with an aftermarket efi install.
you need a General Motors FSM factory service manual for a 1985 corvette,NOT A CHILTONS OR HANES MANUAL! access to a tech 1 scanner, a digital volt ohm meter, a vacuum gauge, as well as hand held vacuum pump. you will also need a timing light as well as a way to test and verify fuel pressure. you should have a breakout harness for the tps sensor so it can be set right. and if you messed with the throttle stop screw odds are you have created some havoc and it isnt going to run right until everything is verified and returned to factory spec. The tech1 will give you codes, limited data. You take that info and reference the manaul where it gives you flow charts and follow it. you will have to check voltage on various circuits, you will have to verify all vacuum lines on the engine are in place without leaks and functioning right. if the intake has years of daily driver duty with 87-89 octane gas it probably needs removed, carbon scrubbed from the crossover ports in the intake, all egr passages cleaned. you will have to verify the engine mounts, cbeam, all engine accessories are in good shape and tight, the exhaust is right, the est module and knock sensor will pick up mechanical problems as knock and retard timing. I could go on and on. do you even know where the est aka knock module is? do you know where the egr solenoid valve is? have you verified base ignition timing is set to factory specs with the est wire disconnected? these are very basic things that every mechanic should have if working on a general motors obd1 vehicle. Do you have them? if not you are pissing in the wind, you will run around in circles, fix nothing, and probably remove good quality factory components replace with chinese junk and make the problem worse. Or, pay a master tech a couple hours labor to troubleshoot and fix the issues. the 1985 tpi engine is very tough, low powered but tough. it is not that difficult to get them to run right. If you cant sort these basic things out you have zero business messing with a microsquirt, its going to have you make connections to the cts, hei,mat,o2, as well as knock module. You just said you cannot find the idle control valve, and are unclear how the factory ecu uses that sensor to control cold idle. I am trying to help you dude. put your ego to the side and listen to what I am trying to communicate to you. Id love to see you out there burning up the streets with your 1985 corvette sir!
