Distributer gear question.
Old Jan 4, 2003 | 08:46 AM
bjankuski's Avatar
bjankuski
Default Distributer gear question.
I installed a TPIS ZZ-9 camshaft in my 1986 Corvette and used the stock distributer gear. TPIS told me it would work fine with their camshaft. I have just removed the distributer after 3000 miles and the distriuter gear is worm pretty badly. What gear am I suppossed to use with the roller camed engines. I was going to purchase a new gear from a 1987 or newer Vette or F-body. Will this solve my problem? Is the high volume oil pump causing the excessive gear wear or is there a compatability problem?
Old Jan 4, 2003 | 10:07 AM
Corvette0096's Avatar
Corvette0096
Default Re: Distributer gear question. (bjankuski)
You need to get a melonized distributor gear. They are for roller cams. Gm started roller cam in 87. Your pump will be fine. I have seen this time and time again. :cheers:
Old Jan 4, 2003 | 11:29 AM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
:iagree: Get the gear from 88 up. It has a grove around the circumference.
I had similar promblem. Dealer has the gears, around $40 or maybe Jeff Kopp can save you some $
:steering:
To Distributer gear question.
