Gear ratio advise, Please
Old Jul 7, 2022 | 10:34 AM
Gooseit's Avatar
Gooseit
Default Gear ratio advise, Please
My 95 model had the performance axle with 3:07 gears. It appears my 96 Auto has the standard 2;59 gears. I can feel the difference and want to change the gears, My question is has anyone went lower than the 3:07 ? I have seen gears in the 3:42 or ratio range. Anyone who has used gears lower than the 3:07 please tell me how you like them.
Gooseit
Old Jul 7, 2022 | 10:49 AM
vader86's Avatar
vader86
3.54 or 3.73 in the D36 carrier are very common, unless you primarily do highway driving up 65/24/40, you should enjoy it.
Also a good idea to think about a better TC than the stock wimpy 1500rpm, a 2200-2400 in an LT1 car is much better to drive off the line.
Old Jul 7, 2022 | 11:22 AM
JD1964's Avatar
JD1964
I’m running 3.54’s in my 96 LT1 D36. Car came with 2.59. Big difference obviously. The only time I miss the 2.59 is on long highway trips. However, with the 3.45 we can still cruise 70mph at roughly 2500 rpm. It’s tolerable. The acceleration difference with the 3.54 is worth the trade. You can have the speedometer corrected in a pcm tune.
Old Jul 7, 2022 | 02:22 PM
Gooseit's Avatar
Gooseit
Thanks for the advise, I will be doing quite a bit of interstate driving so I think should go with the 3:07 gears. I know these 2:59 gears have got to go.
Old Jul 7, 2022 | 02:50 PM
haggar1850's Avatar
haggar1850
Yep, you need to consider your usage. I run a 3.33 geared D44 in my 1992 4L60e car. I'm at ~ 2500rpm around 80mph with the converter locked. Works great for me, but I do 95% of my driving in city @/Below 65mph.
Old Jul 7, 2022 | 03:01 PM
WVZR-1's Avatar
WVZR-1
This I've always thought would be an 'ideal' situation! Much would depend on the price for either an '89 or '90 3.33 D44.
Old Jul 7, 2022 | 11:11 PM
Polo Vert's Avatar
Polo Vert
I've done the 2.59 to 3.07 swap in my last car. Really woke it up. 3.07 doesn't sound like much but it made my 94 touchy with the throttle. Best part is, it had little to no effect on mileage. Still got 26-27mpg highway. I'm going to do the same to my newly acquired 93.
Old Jul 7, 2022 | 11:40 PM
Kingtal0n's Avatar
Kingtal0n
I have a 3.5:1, and I would kill for a 3.07 or even 2.89 ratio. Absolutely keeeeel for it.
The numerically lower ratio improves fuel economy and allows a high power car to achieve higher MPH through each gear and put the increased area under the curve to use. How often does that happen, economy + useful power? Less spinning tires, more top end.
I would say instead of adding gear ratio to make up for lack of power, just add power instead. Consider a supercharger or turbo.
https://www.corvetteforum.com/forums...post1605320283
Old Jul 8, 2022 | 01:22 AM
Gale Banks 80''s Avatar
Gale Banks 80'
The standard Performance Ratio is a factor of 10. In other words take your transmission 1st gear Ratio and multiply it by the Rear End Ratio. So lets say You have a 700r4 or a 4L60e with a 3.06 first gear. Take 3.06 X 3.33 = 10.18 so this is pretty darn close to 10. This is about the best You can do with street Tires. If You have a small cubic inch engine with a lot of Camshaft you might want to run a Ratio of 10.5 or 11. If You have a bigger cubic inch engine with lot of torque the You may want to go to 9.5 even a 9 Ratio. If You are running a TPI Engine its going to fall into the lots of mid range Torque range. Your 3.06 first Gear x 3.07 Gears are going to fall right into this at 9.39. Now for some bad news. If Your planning on getting Your Rear End rebuilt and install new gears despite what every catalog sez 3.54 and 3.73 are about the only gear ratios available any more. And the best US Gear Gears are no longer made and already gone.
Old Jul 8, 2022 | 09:40 AM
Phobos84's Avatar
Phobos84
I love having 3.73's in my 84. I drive it to work on the highway and it's not that bad. But after having it with 3,73's now for so long I can never go back to having less gear.
Old Jul 8, 2022 | 12:20 PM
haggar1850's Avatar
haggar1850
Its really popular ratio with the 4th gen F-body guys who also run 275/40R17s
To Gear ratio advise, Please
