Pinion Seal
Old Jul 7, 2022 | 11:35 AM
ZumZum's Avatar
ZumZum
Default Pinion Seal
I'm need to replace the pinion seal on an '85 D36 3.07 rear differential. I'm looking at several and wonder if anyone has used any of these.
Here's one at ZIP
ZIP Corvette Differential Seal
Here's a couple from Rock Auto
BCA Pinion Seal
Timken Pinion Seal
The ZIP seal doesn't give a lot of info.
I like the BCA seal because it's Viton, but it gives a width of 0.645 inch.
The Timken seal has a width of 0.608 inch, which seems to be a more common width.
If anyone has used any of these seals or had success with a different one I'd like to hear from you.
Old Jul 7, 2022 | 11:38 AM
WVZR-1's Avatar
WVZR-1
Buy 'local' !!! Get yourself a 'new; pinion nut also!
Old Jul 7, 2022 | 11:57 AM
ZumZum's Avatar
ZumZum
I've thought about the pinion nut also, but a lot of what I've read about replacing the seal says to mark the pinion nuts position and reinstall it to the same position.
How would that work using a new nut?
Old Jul 7, 2022 | 12:01 PM
WVZR-1's Avatar
WVZR-1
Pinion nut is a 'Prevailing Torque' fabrication and intended NOT to be reused. Is it often reused? Yes very often.
Old Jul 8, 2022 | 12:38 PM
ZumZum's Avatar
ZumZum
Update:
This is what I ended up ordering from my local NAPA Store
NAPA D36 Pinion Seal
To Pinion Seal
