9th injector removal question
Jan 4, 2003 | 02:12 PM
As you can see from the photo there is hot lead that goes back into the wiring harness. What are you guys doing to remove the injector to coolant temp sensor connector with that hot lead?
[Modified by chucks88, 2:15 PM 1/4/2003]
[Modified by chucks88, 2:20 PM 1/4/2003]
Jan 4, 2003 | 02:16 PM
Re: 9th injector removal question (chucks88)
[Modified by chucks88, 2:19 PM 1/4/2003]
Don't know why the photo isn't showing up :mad
Jan 4, 2003 | 02:35 PM
photo url (http://temp.corvetteforum.net/c4/chucks88/9th.jpg)
btw. dont know answer, i was just seeing if i could get your pic to show. here it is hosted by me.
[Modified by VetteNoob, 1:40 PM 1/4/2003]
Jan 4, 2003 | 02:47 PM
You can just leave it disconnected. It is an independent circuit that uses a timer in the temp sensor. It is not connected to the ecm so no code will be set.
Jan 4, 2003 | 02:51 PM
Mine is just dangling unplugged. :)
Jan 4, 2003 | 03:45 PM
Re: (scorp508)
:iagree:
Jan 4, 2003 | 07:54 PM
Super Ram
Chuck must be getting close by now!
Nuke, be sure to put the smaller"NAWWWZ" jets on my new PC :D :jester
Jan 4, 2003 | 08:12 PM
Re: (scorp508)
:iagree:
Jan 5, 2003 | 10:30 AM
Re: 9th injector removal question (VetteNoob)
Okay, I guess I'll just dangle my injector. :p:
Thanks for posting that photo- noob :thumbs:
Jan 5, 2003 | 01:24 PM
Cruise-In II Veteran
Chuck, if you want to clean up that area just clip the two wires, one shorter than the other, tape them together (or use heat-shrink tubing over the ends) and tuck em into the harness.
Jan 6, 2003 | 02:16 AM
Re: 9th injector removal question (65Z01)
Thats what I did to mine..just clipped them..put on some heat shrink and tucked them inside the loom...no problem
