Flash to pass?
On the 66 mentioned in this thread the headlights and the flip motors are on separate switches. You rotate the lights up with a switch, turn the lights on and off with another. That was nice... basically when you are in traffic you can leave the lights up but off... then flash as needed.
C4, flash to pass means just turn the lights on. The flash part is the difference between lights on and off and there isn't a bigger change than rolling the lights over. It's better than a normal car honestly
Anyway, to the O.P.'s question, I'm not aware of a kit, but it would be possible, in theory, to tie the high-beam switch to the fog lights.
You'd need to spend time with the electrical schematic to figure out where to tap in to the high beam switch, and if there is power to it when the headlights are off. You'd also need a relay to disable the feature when the headlights are on so the normal high beams don't turn the fog lights on.
That being said, is it worth all that effort considering how clueless most drivers are? Witness a few of the comments in this thread alone.
PS: Keep in mind who started this ****.
That's for the Y and Z generation.
Case Study 7: The $2.5 Billion Cross-Border Expansion Mistake by Target. Less than two years after entering Canada, Target shocked the retail world by pulling out. After accumulating $2.5 billion in losses, the Minneapolis-based company shut down all of its 133 Canadian locations and laid off 17,600 employees.
Sounds like Canada is not the place to invest money in a store! If everyone up there acts like Arbee I can understand why they left!
I suppose there are some countries disappointed that the Obama apology tour of the world has passed and is long forgotten as it very well should be.
if you can't tell, this issue is a pet peeve of mine along with not dimming your lights to oncoming traffic, and that IS against the law.
On the plus side, if nobody has done it to you, it means you're probably not blocking the passing lane, so that's good.
That's what traffic laws are for. Wait for the dotted line, check YOURSELF that it is safe to pass and make your move quickly and safely. Your "permission" is not required.But do you see where someone might think they're getting a hard time from someone who is misinterpreting the question?
"Pro" truck drivers need all the help that they can get, to not **** it up. In fact we have some "pro" truckers right here on these very forums who've shown us justhow"professional", semi truck drivers really are.
OP, Leave your fog lamps on all the time (fog lamp button depressed). When you want to flash, flick/alternate the headlight switch between "Off" and "parking" lights and your fogs with flash on and off. I do it a LOT, for "Left Lane Losers". And yes, that even includes "professional" truckers.
Run a jumper wire from the low beam side of the hi/lo beam switch, to the powered side of the hi/lo switch....then you have both on all the time that the "hi's" are on, w/o having to hold the lever.
As for someone saying it is standard, I don't think that is true. Every C4 I have ever been in, you had to turn the headlights on for the headlights to light up. There is no "flash to pass" as there is in most modern cars where they come on by pulling the turn signal stalk.
