86 C4 Clutch Will Not Bleed
Bleeding the brakes went great, and all 4 calipers now have clear DOT 3 fluid running through them when bled. I went to bleed the clutch, which started out fine. I had someone else press in the clutch, then I'd open the bleeder on the slave, close the bleeder, then have them let go of the clutch. Did this multiple times with no issues and no air in the lines, just dirty fluid. After refilling the master cylinder a time or two, I got carried away and let the master cylinder empty, allowing air into the line. I refilled it with fluid and tried the same method to bleed. I got the old fluid bled out (the fluid in the line before I let air in), but after that was all gone, nothing was coming out anymore. By this point the clutch has little to no pressure, and the slave piston barely moves a centimeter when the clutch is depressed. I have the slave unbolted from the bell housing and at a 45 degree angle. I tried getting a vacuum bleeder and pumping from the slave bleeder, but still no luck. One thing I do notice is that when I push in the slave piston manually, the level of fluid in the master will rise. I've tried the conventional two person method, as well as using the vacuum bleeder method multiple times, but the clutch still has no pressure and the slave doesn't move. The master cylinder fluid level does not drop at all through any of these bleed attempts. It stays at a constant level the whole time. Yesterday I got the slave to move slightly more by pressing in the slave piston manually, having someone else depress the clutch, and then opening the bleeder. A few air bubbles came out, but if I went to bleed again, as soon as I open the bleeder valve, it only wants to suck in air/liquid. I have tried pumping the clutch pedal a bunch, have tried pumping then holding the pedal for a few minutes and letting it spring back up, but still no luck. Both the master and slave were working perfectly fine beforehand, and I see no signs of leakage, so I want to say that those aren't the issue. Note that the back of the car is jacked up very slightly lower than the front, only by an inch or two.
I would sincerely appreciate if anyone could help me get this clutch system working again. What was supposed to be a half a day job has now turned into 4+ days of trying to bleed. Thank you.
Suggest that has seemed to always work in the past
Remove slave cylinder from vehicle and then bleed the system, with the bleeder screw at the highest position possible. With the slave cylinder extended--the fluid is being pushed out and the clutch will feel "solid" like a brake pedal when properly bleed and bleeder screw closed.
No movement of the slave cylinder and 100% fluid, which cannot compress = solid feel to clutch pedal.
To install slave cylinder, crack the bleeder screw to retract the cylinder enough to bolt in place, tighten bleeder screw.
Then re-bleed should be "zero to no air" in system.
Clutch should disengage properly.
If clutch does no disengage, check travel of slave cylinder--should almost extend to maximum point
If no travel or minimal travel--suspect master or slave leaking internal/external.
These rebuilt parts are getting to be junk. We C4 owners are going to have to find another option for clutch master cylinders soon.
circulated fluid until all air out. found tapping the whole system helped get air that was clinging to insides out.
This works. PUMP THE PEDAL. You don't have to do full strokes and you don't need to hold the pedal down all night. All you need to do is move the fluid/air back and forth in the system...and cover/uncover the replenishing port in the master cylinder...that takes about 1" of clutch pedal travel to accomplish. I find the fastest/easiest way is to open the driver's door, and squat down by the rocker rail, reach into the car w/my right hand and just tap the clutch pedal down about...maybe an inch? or so? I Occasionally I'll throw in 1 full pedal stroke. Why use my hand? Easier and faster than with my foot. I can tap that pedal pretty fast with my hand/fingers. I've gone from a completely empty system, to fully bled, awesome pedal, in about 2 minutes or so.
fwiw, in my case, i swear on my life i pumped the pedal more than 1000 times. i never could get it fully cleared of air. not sure why. to be honest there was probably somewhere letting air in.
I don't care why this works.
But I know this works.
Pump the pedal 10 times and hold it down for 30 seconds. Release the pedal by sliding your foot off it to the side, allowing it to spring up.
Do this a few times..
It works!
1. You barely had any air in the system and it was near the top (hence "10 pumps")
2. Air wants to rise to the top. This method is called "back bleeding" and is a very common procedure on small hyd systems such as dirt bike and snowmobile brakes, mtn bike brakes and so on.
If the system had more air in it, it would take a lot more pumps. See post #6.
