1987 no start problem
Old Jan 5, 2003 | 10:00 PM
garebel's Avatar
garebel
1st Gear
Default 1987 no start problem
Need to locate Starter Enable Relay and Decoder Module.
Old Jan 5, 2003 | 10:10 PM
DRAGRCR1005's Avatar
DRAGRCR1005
Default Re: 1987 no start problem (garebel)
not sure on the decoder but on my 92 the relays are lined up just under the driver and pass feet just under the lip of the dash. try to switch the relays with one and another, they are most of the time the same and are interchangable. another possible cause is the neutral saftey switch or the clutch petal switch(MANUAL TRANS). :flag
Old Jan 5, 2003 | 11:07 PM
fundriving's Avatar
fundriving
On my '86, Starter Enable relay is behind the center I/P, easiest acces is by taking out the radio/HVAC control. The VATS decoder is between the center I/P and the ECM (which is under dash on passenger side.)
To 1987 no start problem
