How to Remove Front Leaf Spring!!! HELP!!!
Old Aug 15, 2022 | 11:21 PM
mit01006's Avatar
mit01006
Cruising
Default How to Remove Front Leaf Spring!!! HELP!!!
I'm trying to change out the front suspension and can't seem to figure out how to get access to the top bolts of the leaf spring. I don't want to pull all the accessories if possible, but can't seem locate the tops of the bolts. I have all the other suspension components out, but can seem to figure this on out.
Old Aug 16, 2022 | 09:39 AM
AZSP33D's Avatar
AZSP33D
The center supports unbolt from the bottom, and there are nuts on top you just need to get a flat wrench on it. The lower control arms have easily accessible bolts.why are you removing the spring?
