Getting ready to replace the Opti in my 92 LT1 with one someone gave me that I modified to be vented. Before I go through all the trouble is there a way to bench test the Opti prior to replacement?
Re: Anyone know how to bench test an Opti? (PTz-92-LT1)
I did this once for the low-voltage section.
You can apply the regulated +5 volts to the Opti-Spark from a well regulated power supply. Then, by hand turning the Opti-Spark shaft, you can view the low-resolution and high-resolution signals with an oscilloscope or voltmeter to see if they exist.
Or, just plug in the Opti-Spark with the ignition coil and injectors disconnected and turn the shaft while monitoring the low and high res signals with an oscilloscope, meter, on scan-tool.
I never did a bench check on the high-voltage section -- didn't want to hold it while 30KV was bouncing around.
This response is just to provide you with something to think about. The diagnostic test on an opti is quite complicated and requires know-how and instruments. Assuming you have the experience and tools, even if the opti checks OK, you are working with a used part that has suspect longevity. This component is so critical to the operation of your vette that I would recommend buying a new opti from {Non-supporting vendor} (Jeff Kopp $265), or Dyno Tech (a participating sponsor - left column @$500), with warranty provisions. There is just too much labor involved replacing an opti to rely on a used part. Good luck with the install.....
