1987 Corvette running poorly and bogging down! !NEED HELP!
Old Aug 19, 2022 | 01:40 PM
87PeterC4's Avatar
87PeterC4
5th Gear
Default 1987 Corvette running poorly and bogging down! !NEED HELP!
So I recently bought a 1987 Corvette and I have been having issues with the car running properly.
the issue is as follows the car starts up ok, it takes a couple seconds but it eventually gets going, right after starting the cars rpms at idle fluctuate between 6-800 rpms before I put my foot down on the accelerator, when I put my foot down the car very roughly revs up and wont really rev very high before it starts to run very very bad, the car bogs down immediately after releasing the pedal at any rpm over idle.
What I have done to try and fix this issue is as follows:
new fuel pump, new fuel filter, new mass air flow sensor, new idle air control valve, new oem ignition module, and a new battery.
a note to add are that the car does have 200k miles, I did check the spark plugs and they looked clean, ALSO the catalytic converter is making a rattling noise which might be a problem I'm just not fluent enough with cars yet so I don't know yet. If anyone has had any similar issue please feel free to help any input is appreciated, thanks!
Old Aug 19, 2022 | 05:37 PM
THE 383 admiral's Avatar
THE 383 admiral
Sorry to hear that.
Ran fine. then happen all of a sudden. Or over time.?
No results with the multi parts.
What about the cap, rotor condition, timing, fuel pressure PSI, vacuum leaks. Did you pull the plenum? That plenum can give a good challenge if not familiar.
Post a sound or vid clip. Start, idle, gradual rev to 2k.
To hear what is going on.
Old Aug 19, 2022 | 07:03 PM
ex-x-fire's Avatar
ex-x-fire
I'd start with cleaning the injectors or having them serviced/cleaned. I have an injector cleaner tool that hooks up to the fuel rail and it runs on the cleaner for 20 minutes or so. The cleaner I use is BG44k.
Old Aug 20, 2022 | 02:56 AM
87PeterC4's Avatar
87PeterC4
5th Gear
so bought the corvette about a month ago in the condition I described, the guy didn't know what was wrong with it either as he didn't know really anything about cars. To be fairly honest I myself know very little in comparison to most of the people on this site, I'm just learning as I go and hoping to learn some valuable skills. I will throw up a video on my post when I wake up tomorrow though so everyone can see how it runs.
Old Aug 20, 2022 | 10:19 AM
s carter's Avatar
s carter
There two sounds that come from catalytic converters 1 is a tinny heat shield or pipe separation usually reduced by sqeezing with channel locks or some pressure with a screwdriver.
annoying sounds not a car stopper
Second is a hard rattle that sounds like a box of rock's rattling a very solid sound, some at first impression will say the bottom end is gone. But its not it's just the fact that the upstream converters have self destructed and are now trapped against the main converter. Bad news is if this is the case lower converter is now beaten to death also.
What does this have to do with poor running cars need to breathe and your car can't exhale, your exhaust is clogged
(Car Stopper)
Old Aug 20, 2022 | 01:55 PM
87PeterC4's Avatar
87PeterC4
5th Gear
(Car Stopper)
Yes! it sounds like a bucket of bolts from the cat! I did some research and I thought something like this might have been the problem. Hearing someone else reiterate that idea makes me think there is a good chance this could be the issue! thank you!
Old Aug 20, 2022 | 01:56 PM
87PeterC4's Avatar
87PeterC4
5th Gear
I will look into it, I have been running sea foam through it but I'm sure getting the injectors properly cleaned can do more than sea foam. I will give it a try then, thanks!
Old Aug 20, 2022 | 02:13 PM
s carter's Avatar
s carter
I would hold off on the sea foam there is controversy on it creating problems, I have always used the Tech-Chron for a quick clean the 3M for deep clean that hooks to fuel rail like what other had mentioned.
Old Aug 20, 2022 | 02:17 PM
87PeterC4's Avatar
87PeterC4
5th Gear
ok heard that, I will add that to the list, had no idea it could cause problems, thank you for letting me know. I will look into the other cleaners.
To 1987 Corvette running poorly and bogging down! !NEED HELP!
