92 Air pump
Old Aug 23, 2022 | 11:05 PM
rberge12's Avatar
rberge12
Default 92 Air pump
Good evening all,
I found an "unused" connector in the front drivers side, found out (from this GREAT board) that it was the relay for the air pump. I put a new relay and can hear the pump run. I also no longer notice a fuel smell when I start her up
My question is would the air pump cause the engine to run hotter? I noticed that normal for my LT1 is about 198, after the pump was hooked up it ran at 215..
Is this possible?
thanks
Old Aug 24, 2022 | 06:48 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
As above your air pump has nothing to do with engine temp. You probably need to go over the basics of cooling; check your fluid, make sure your fans are working and see if there is any obstructions (that means clean) in front of the radiator or in between your condenser and radiator.
Old Aug 25, 2022 | 02:08 AM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
Originally Posted by IHBD
I had an out of the box thought regarding a correlation between the AIR pump and higher engine coolant temperature. Hat tip : @VikingTrad3r he reported this on one of his cars:
A clogged or restricted cat converter can cause elevated operating temperatures.
If the AIR pump is running at all times (It is not supposed to. Only for a brief period after engine start) the secondary air in the exhaust will cause elevated cat converter temperatures, and may damage (melt) the core.
thats an interesting theory about the pump running continuously. maybe thats why it was unplugged. a guy could use a laser temp gun to get a reading on the cat with it plugged in and not.
Old Aug 25, 2022 | 08:12 AM
rberge12's Avatar
rberge12
interesting theory, in the FSM it states that the pump should run for a max of 240 seconds. 4min, I will time it today
Old Aug 25, 2022 | 04:04 PM
rberge12's Avatar
rberge12
Ok, again thanks all
Verifed it ran for 3 min 48 sec Guess its doing what its sposed to do!
To 92 Air pump
