'94 Battery Drain - Chasing my tail
Old Aug 29, 2022 | 11:25 AM
danielhv's Avatar
danielhv
6th Gear
Default '94 Battery Drain - Chasing my tail
Chasing a battery drain issue on a 94. Disconnected negative battery cable, I pulled the courtesy fuses, disconnected hood lights, closed the doors, hooked up my multi-meter, and got a 400-500mA draw reading. Pulled fuses one by one. When I got to the CCM2 fuse, it dropped to 16mA. Can't imagine that being normal... I thought it may be the radio, it's aftermarket and wife tells me it powers off then back on randomly during a drive. I have confirmed this, it just restarts without reason. I removed the radio and still getting a .424mA draw with everything off.... Any other suggestions?
The battery (less than a year old) doesn't make it a week before it will no longer start the car...
Old Aug 29, 2022 | 12:33 PM
JimArn's Avatar
JimArn
My late brother had a similar problem with his boat radio. The radio had two "off" settings; one for the audio and one for remote sensing. He was leaving the remote sensing on. Could be your problem too.
Old Aug 29, 2022 | 02:28 PM
Riley93C4's Avatar
Riley93C4
I have been chasing a similar battery draw on my '93. I have my courtesy switches on the doors failing, that's one cause. Linked to that is my amps on my speakers going bad. I still have to test a bunch of other things. There is a fuse tester that harbor freight makes that plugs into the fuse slots.....a little easier than multimeter on battery and pulling fuses. In the meantime, I bought a negative battery cable kill switch. That way I can still enjoy the car. When I shut the car off I pop the hood and hit the kill switch. 10 second inconvenience. Good luck.
Old Aug 29, 2022 | 02:52 PM
danielhv's Avatar
danielhv
6th Gear
Originally Posted by IHBD
CCM 2 is the battery supply to the CCM. The .424mA draw indicates that it was still "awake" when you tested. Section 8D in Book 1 explains the wake-up inputs, and conditions under which the CCM goes "asleep".
Some inputs that may be affecting your testing:
PKE Fob within range.
Key is in ignition (Stays awake for 30 minutes).
A ~.500mA draw will discharge a healthy battery in about 4-5 days. The CCM draw is most likely the cause. The cause of the draw is that the CCM is not going into idle mode. Something is keeping it "awake". Understanding the CCM strategies takes some time studying an FSM. But in the meantime, I'd re-test your draw being sure the PKE fobs are out of range, and that the key is not in the ignition. And wait at least a couple of minutes for the CCM to hibernate before accepting the reading. I'd also leave the meter set up for an overnight test. If the reading remains at .424 overnight (it probably will; because the battery eventually goes dead), yes, there's something keeping the CCM awake. I'd suspect the PKE system.
This has been the most detailed explanation I've seen on this problem. Thank you.
I don't have any FOB's because the previous owner lost them. But I will try again with the key out for a while and report back.
Thanks again!
Old Sep 2, 2022 | 09:43 PM
danielhv's Avatar
danielhv
6th Gear
Ok, so I let it sit for about 3 hours, key is inside the house. We don't have a FOB. The meter dropped to .413 but no lower, so something is definately keeping the CCM awake. Unless there is a Fob lost somewhere in the car from the previous owner - I'm at a loss as to figuring out what is keeping this thing awake. Any suggestions on further troubleshooting?
Old Sep 2, 2022 | 11:02 PM
pcolt94's Avatar
pcolt94
I understand the problem and made those measurements myself. I have watched the current go down to 30 ma as the lights go off and the CCM goes to idle.
Somewhere I read if the key locks were not in the vertical position it can cause a problem. I just can't remember the exact conditions. But I would rock the key locks and then go to the vertical position just to make sure.
Want to check to door light plungers for adjustment and that the lights are out in the center console and under the hood.
In regard to the PKE comment, you can always pull the fuses for it in case it is active.
Old Sep 3, 2022 | 12:43 AM
danielhv's Avatar
danielhv
6th Gear
I'll take a look at the plungers, but the interior lights do go out when the doors get closed. Hood lights I disconnected prior to running the tests. Not quite sure I understand the part about the door locks but I will see if I can make sense of it tomorrow when I can go out there and look at the locks.
Will pulling the PKE fuses mess with anything else? Car will still function fine?
Old Feb 20, 2023 | 06:39 PM
barry96's Avatar
barry96
I thought I hit the jackpot when I read the first post so I was disappointed to see the thread end.
I have the dash still off from replacing the heater core last month and while open I fixed the chime module (see my other posts/threads if interested). I was going to replace the PKE that I turned off 10 years ago because the alarm started going off for no reason and when the rear hatch opened while driving, I had enough. So now that everything is open, it was time for the PKE.
But something happened during my break from working on the car (it was running just a few days before) and I came back to a totally dead battery. When I hooked it up to the charger after it got a bit of juice, when I opened the car door, I heard a clicking noise. I didn't know what that was at the time but now a few days later, battery charged up and I got a multimeter with a higher DC amp range than my little one, I hooked it up inline to the battery and saw it was draining about 300+ mA. Strangely the courtesy lights did not turn on (did CCM read too little voltage to turn them on?) but the clicking noise was back. I started pullling fuses and after pulling the CCM2, it dropped to 25ma.
So now what?
To '94 Battery Drain - Chasing my tail
