Help identifying electrical connectors
Old Sep 7, 2022 | 06:40 AM
NickPSI's Avatar
NickPSI
Default Help identifying electrical connectors
Hello, 1985 4+3 disaster rehab of a car. Under the driver side dash and the majority of the wiring is hacked up for what may have been an old alarm system. There is alot spliced or not connected. Here, the spade connector looks like a ground but I don't know what these other two are. These are on the drivers side hanging under the cluster/column
Old Sep 7, 2022 | 07:31 AM
s carter's Avatar
s carter
Cruise control flat plug goes into the square connector with white tab.
Do your Hazard lights or directionals blink because the other looks like a timer plug
Old Sep 7, 2022 | 08:33 AM
NickPSI's Avatar
NickPSI
Hazards work, I just replaced the flasher for the directionals so they work now that was on the passenger side behind the breadbox.
Old Sep 7, 2022 | 12:41 PM
s carter's Avatar
s carter
Since all the other plugs you are showing are Cruise, that might be a Cruise disconnect switch wire on the clutch pedal or possibly on brake pedal
Old Sep 7, 2022 | 12:55 PM
WVZR-1's Avatar
WVZR-1
The connector @ your 'index finger' looks to be an early CSS (Clutch Safety Switch) connector. That would be from the switch. Wire colors are?
Old Sep 7, 2022 | 12:59 PM
NickPSI's Avatar
NickPSI
Originally Posted by WVZR-1
The connector @ your 'index finger' looks to be an early CSS (Clutch Safety Switch) connector. That would be from the harness in the car. The CSS would have a mating connector. Wire colors are?
That makes sense, as the car can be started without the clutch depressed. I'll see if I can find where it plugs in.
Old Sep 7, 2022 | 01:14 PM
WVZR-1's Avatar
WVZR-1
Do you have the FSM? What are the wire colors.
Old Sep 7, 2022 | 01:45 PM
NickPSI's Avatar
NickPSI
The connector on the right is 3 blues, a green and pink. Center is black (duh) left is black/black.
I do have the fsm
There's also this heavy green/yellow that is jumped out:
Old Sep 7, 2022 | 01:52 PM
WVZR-1's Avatar
WVZR-1
The jumper is CSS to the body harness 'jumped'. The first one in your 1st post is from the switch with likely 2 black wires. I fixed post #5.
Old Sep 7, 2022 | 02:20 PM
s carter's Avatar
s carter
I was suspecting the Clutch Switch but since he Didn't mention a bypass all that wiring was connected and functioning, OP anytime you have Creative wiring its kind of important to mention. Because all you needed to do is look up and trace 4" to clutch switch
To Help identifying electrical connectors
