Seat Belt Installation
Old Sep 23, 2022 | 09:18 AM
bp308's Avatar
bp308
Default Seat Belt Installation
I hope this question falls under tech so I have it in the correct section. I am replacing the seat belts in my 91 L98 Coupe. I did this once before, but as soon as I moved my seat back it basically crushed the seat bealt retractor assembly. Can anyone offer a suggestion to prevent this? Can any seat belt retractor be mounted on the pillar or only a special type? Is this idea even recommended (safety issue etc).
Thanks in Advance
Old Sep 24, 2022 | 07:44 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
Thanks in Advance
are these factory belts? factory seats?
Old Sep 24, 2022 | 08:15 PM
bp308's Avatar
bp308
After market belts, original seats
Old Sep 24, 2022 | 08:45 PM
VikingTrad3r
Oil Producer
well there is your problem. get some off ebay.
Old Sep 27, 2022 | 01:54 PM
bp308's Avatar
bp308
Are you saying aftermarket belts won't fit, or get different seats?
Old Sep 27, 2022 | 02:14 PM
THE 383 admiral's Avatar
THE 383 admiral
Almost every car manufacturer specifically designes each interior with a specific belt for safety.
With that said. Many manufacturer's had cookie cutter models. Example. GM, the regal, caprice, Parisienne, main difference sub company, olds Pontiac, Chev. Past time now.
Also. The vette shares no common ground.
Hence your aftermarket belt was crushed.
The vette is first in line other models release the next year.
Old Sep 27, 2022 | 02:18 PM
bp308's Avatar
bp308
Thanks, makes sense
To Seat Belt Installation
