Guess my Dyno
Old Jan 10, 2003 | 11:54 PM
BBA's Avatar
BBA
Default Re: (CORKVETTE1)
the graph does not show horsepower equals torque at 5250 rpm there is something wrong with that dyno.
The scales are different for torque and HP...and they are right
Old Jan 11, 2003 | 12:15 AM
scorp508's Avatar
scorp508
guys look at his first graph it is jaggy too plus the graph does not show horsepower equals torque at 5250 rpm there is something wrong with that dyno. torque always equal horsepower at 5250 that is a constant the jaggedness is ill bet it is slipping all over that dyno :cheers:
Umm.... Corky....
[whispers] Look at the two sides, it is using different scales for each. [/whispers] ;)
Old Jan 11, 2003 | 12:27 AM
GusBustamanteJr's Avatar
GusBustamanteJr
Default Re: (BBA)
"If your iac counts are high...it means your min idle is set too low to start with...in effect, its the opposite of a vacuum leak, so checking for a leak is a waste of time."
Okay, so how do I set my min idle?
I always set the TPS voltage first, then adjust the throttle linkage to idle around 800 rpm, and re-check the TPS voltage.
Is this wrong?
Old Jan 11, 2003 | 01:24 AM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: (GusBustamanteJr)
scorp and everybody else i was wrong i was reading the graph wrong duh :yesnod: :cheers:
Old Jan 11, 2003 | 01:40 AM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In V Veteran
let me take another stab at this if it was running out of fuel from filter and or pump i do not think it would be pulling so hard after it went full lean on the graph the af came back in line if it was running out of pump or pluged filter that would not have happened :cheers:
Old Jan 11, 2003 | 10:18 AM
GusBustamanteJr
Yes, that makes sense....
Im going to check EVERYTHING today regardless. It cant hurt!
BTW the weather today.....
Very Sunny, not a cloud in the sky....about 65 degrees.....FREE AC IN THE GARAGE!!!!! WOOHOO!!!!
Old Jan 11, 2003 | 10:38 AM
GlennS87's Avatar
GlennS87
I personally wouldn't trust a wideband O2 that takes it's readings after the catalytic converter. I have had both done, tailpipe sniffer and the extra bung I had put in the header and their definitely was a difference. Unfortunately, I lost the dyno graphs so I can't post them.
That being said, the relative leaness in parts of the curve do have to be addressed as was mentioned earlier.
Old Jan 11, 2003 | 11:33 AM
GusBustamanteJr
Default Re: (GlennS87)
The car has had all of its cats removed
Old Jan 11, 2003 | 12:20 PM
scorp508's Avatar
scorp508
One thing at a time. :) I think we can assume the fuel pump is good due to the fact that the A/F came back into good territory at such a high RPM. If the pump couldn't keep up there is NO way it would be able to feed the engine at 6000 like that.
So... whats left.
1. Vacuum leak? (none detected so far)
2. Tuning? (my bet, nothing is right the 1st time)
3. ?????
The engine was lean no doubt and it also was getting knock retard of upwards of almost 8 degrees from what I saw. The problem is if that knock is being created from the lean condition or just from too much timing. I'm going to bet a lot of it will disappear once the A/F is brought into a more acceptable level across the board.
At the very least I would start with adding a bunch of fuel from the 4000-5500 range. Regaurdless if there is a vaccuum leak or an exhaust leak there should be a somewhat constant trend in the A/F readings. That baby has a huge camel hump in it. You'll see that nasty drop in power at 4900 go away and things should start to smooth out.
Once things get squared away with the fuel you should be able to play with the timing some more and more finely tune the fuel at that point.
Old Jan 11, 2003 | 01:09 PM
GusBustamanteJr
Default Re: (scorp508)
Base timing was just set after rebuild- right at 6. A new knock sensor wouldnt hurt, huh??
Im working on those items right after I test the Camber Brace I just installed...that thing looks sweet in there!!!!
About the heated O2, I could wire it up the the ECM lead right?
Also, a few threads up, I asked the process for adj the idle....was that correct?
Old Jan 11, 2003 | 02:35 PM
scorp508's Avatar
scorp508
Well your knock sensor is working since the ECM is reducing timing, but I mean working with the timing internal to the chip.
A heated O2 is always good. You could wire it up to the fuel pump relay so that it is only switched on when the fuel pump is running.
As for the idle, I don't know that one. :)
Old Jan 11, 2003 | 06:42 PM
GusBustamanteJr
Well today I fixed the idle problem. Seems the TPS had lost its setting, and we didnt set the min idle setting with the IAC unplugged. I followed the tech tip, and its idling great now.
I might do the heated O2 tomorrow.
Tonight we are going out to eat and relax with the babies!
What the wife doesnt know is that they are having a cruise and show at the place we are going to eat!!!!!
