Anybody running a Terminator X ?
I recently purchased a Terminator X universal kit #550-936 for my 1989 L98 and have not installed it yet.
Tuning Holley EFI is almost easy by comparison to a factory ECU/PCM. A lot of guys (myself included) don't need a tuner for a street car. As long as you don't mind leaving a couple hp on the table and you have some patience you can tune it yourself.
I tuned my 89 TA purrRd like a kitten, slight gallop idle. With 1.6 RRs
Manufacturer's Part Number:
08-306-8
Part Type:
Camshafts
Product Line:
COMP Cams Computer-Controlled Camshafts
Summit Racing Part Number:
CCA-08-306-8
UPC:
036584780595
Cam Style:
Hydraulic roller tappet
Camshaft Use:
Street/Strip
Basic Operating RPM Range:
2,000-6,000
Intake Duration at 050 inch Lift:
230
Exhaust Duration at 050 inch Lift:
244
230 int./244 exh.
Advertised Intake Duration:
290
Advertised Exhaust Duration:
307
Advertised Duration:
290 int./307 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:
0.510 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:
0.540 in.
0.510 int./0.540 exh.
Lobe Separation (degrees):
112
The tuning capability is especially nice, and I’ve taken the Holley EFI 1-3 training classes to help with that. I’ve done a lot of ECU tuning for decades starting with the SCT Pro Racer Package and chip burner over 20 years ago, and also operated my own eddy current dyno for many years more recently (sold it earlier this year). Anyway, I can help out if needed, and it’s common so support network is great, and there are a lot of remote tuners out there. I’m running a TPIS ZZ9 cam retarded two degrees for some over rev (6500) and the tuning capability really helps make the most of it.
Building a 400cu in forged bottom small block and a custom Mike Jones cam as of late, and I can’t imagine trying to tune that with the GM ECM.
My ls swapped C4 has been on term x for a few years now. The quality control is hit or miss. My first kit had a dead ecu right out of the box.
my 2nd kit had some bad wiring and wouldn’t turn the fuel pump on-confirmed by another known working harness. Another kit I had the ecu go bad as well. Easy install but there’s no reason to run one on your 200hp sbc 😅
So I might end up using the Holley just to get caught up with the times. Having read other threads I'm still confused on how to tie the original ECM with a Holley to keep the gauges etc going. Is the Terminator X easier to install than the other systems or are they all the same ? I don't see a problem installing the Holley to run the Engine, I have installed a Accel Gen 7 before. I'm not looking forward to making the Corvette stuff run.
What is the normal (map) kpa at the desired idle rpm?
What is the desired spark advance for the known rpm and kpa at the desired rpm?
1940s method: Set the spark advance to a fixed value across the board. Let's say 26-30 degrees as a compromise. Should start, idle and make reasonable power with fixed timing, then work on fuel (VE)
https://www.holley.com/blog/post/hol...dule_for_2022/
What you need to do is figure out how many I/O points you need before you buy something. You may get a Terminator ECU and find out that it doesn't have enough outputs. Or maybe you need a PNP output. The Terminator can't do that but the Dominator can. So you need to be looking at what electronics you are going to connect to the ECU. The Dominator is an amazing piece of hardware. But it's also $2K. No sense in getting it if a Terminator or an HP would work.
heres a solid class from Devin at HCR, December.
