inner window felts
Old Oct 12, 2022 | 10:00 AM
johnfin's Avatar
johnfin
Default inner window felts
Have any of you guys replaced the inner window felts. They appear to be stapled to the door panel. What is the method to replace them?
Old Oct 12, 2022 | 01:22 PM
FostersPerformance's Avatar
FostersPerformance
I have a brand new unused set i bought a few years ago, but ended up buying new panels complete....but if im not mistaken,, the new ones get riveted to the panel.. i can look tonite at the new ones i have and see.
Old Oct 12, 2022 | 05:00 PM
jazfe's Avatar
jazfe
I replaced mine a few years ago and I stapled them. I used a T50 hand stapler and bent the tabs over with plyers.
Old Oct 13, 2022 | 10:35 AM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
myself i riveted. worked great.
to the OP...getting the inner sweeps off of an old early car is tedious and time consuming. The risk is breaking the plastic. the staples used by the factory were like adamantium iirc. my recollection is that i used a dremel cut whell to cut the staple, then pulled/fought with each leg. i remember thinking there must be an easier way but i couldnt figure it out!!
Old Oct 15, 2022 | 12:03 PM
Brandon Iron Smithe's Avatar
Brandon Iron Smithe
Heating the inner panels up will prevent them from cracking when you staple them
To inner window felts
