84 corvette head light motor question replacement?
Old Oct 25, 2022 | 09:52 PM
Nickydowns's Avatar
Nickydowns
Default 84 corvette head light motor question replacement?
Guys I know I can rebuild the original motor also change the gears. My question is can’t I just buy a new modern motor? I see on eBay the newer motors like in the 86 or so. It has 2 wire. I believe the original 84 is 3 wire I’m assuming 1 is ground.
has anyone just replaced the motor with a modern one? Instead of rebuilding the original? If so what motor should I get o see some for 60-75 bucks. Also if so how should I wire it. Do I need anything else
