Warm 4L60E in Hot Mode????
. My speed was about 19mph at the time too. Any knowledge on this issue is greatly appreciated.
Google and others have it backwards as 59
It would appear. the trans temp sensor failed.
Similar to a CTS. Should be a fairly simple replacement. Should be just above the shifter select cable. Front of pan DS.
Inappropriate.. But. Someone could resolve 4L60(e) series simple UN [ ]
If the temp was in fact proven wrong.
96 OBD II PCM i would image very similar.
We have been talking daily and trying to figure it out. I have a new battery coming for my laptop and I am going to datalog the engine on my car to get a good baseline to look at. There could be some faulty wiring, or what he was using before (Tech2Win) through a different cable, could have been reporting wrong.
OR it could be a bad ( - fill in the blank -).
Part of our issue is that I am always a day or so behind, some of the things he is running into, I have no knowledge of yet (so I have to also do research) and I am running a deadline into winter when the car will no longer leave the garage.
Using the forum here as a sounding board, repository of knowledge (which there is a lot) is good practice.
We know the original owner did some stuff. There are semi roller rockers in it (roller tip)
I've lost track of what his malfunction IS.
IIRC, it won't shift out of second, correct? (This is the root problem he's chasing?)
If "No 2-3 upshift" is what he's trying to solve, here's what I'd try. Unplug the transmission connector. Or pull the fuse for the power to the transmission, in a 95 it is the VALET fuse. (I don't know which fuse it is in a 96). Go for a drive. With the shifter in D4, the transmission should be in 3rd gear only. {3rd gear solenoid state is OFF-OFF, same thing as no power to the transmission.) If there is NO 3rd Gear, the transmission has internal problems.
I figure that since I have a low mileage car with no mods (it just now turned 28,000, had 12,000 in 2016 when I bought it), runs great, that it would be a good baseline to compare readings against.
I like mechanical gauges that you know are reporting correctly. In my Duramax, I put in an oil temperature gauge so I can keep a read on that. Now that I am well and over last fall's little issue, I am going to start building the car and will put in more mechanical gauges in a windshield pillar gauge pod.
We both are learning !
4l60e overheating site:sonnax.com
I have found some info on the web talking about wiring issues and false signals
Try not let it pass 175*F much.
My absolute max is 185-190*F then let it cool.
Its hard to keep cool. But if you want the max lifespan this is a necessity.
https://www.dropbox.com/sh/n68x59ly6...6seTawTha?dl=0
Thanks again
With the shifter in D4, did you get 3rd gear only when the fuse was removed? ( Make a note of RPM @ certain Road Speeds when in 2nd. With the fuse removed, if it is in 3rd, the RPM will be lower for the same Road Speeds.) Again: If you don't have 3rd gear only with the fuse removed, it is an internal transmission problem.
My apologies chief.... When I removed the fuse, it didn't go into 3rd. In fact, it did exactly nothing. It stayed in the same condition, No up-shift passed second. But... I HAVE to depress the pedal quickly in order to get it to fully engage into 2nd. As if I was driving a manual transmission, but still no 3rd or 4th.
