headlight question - electrical issue/confusion
Old Nov 13, 2022 | 09:11 AM
Vets-Vet's Avatar
Vets-Vet
If you get the pins right and you are sure the voltage is right and it does not move then it is the motor. The + voltage from the battery must go in on the correct pin and the - ground from the battery must also go in on the right pin. If you have them reversed it will not work
Old Nov 13, 2022 | 09:58 AM
sb66's Avatar
sb66
thanks - i really appreciate the help with this - i am going to try again later today triple check how I have everything i think that first time i read it wrong and was rushing that night to try it out - i will have more time this afternoon
thanks again for the patience and help
