Lt4 Fuel Injectors
Nov 19, 2022 | 01:23 AM
Lt4 Fuel Injectors
Has anyone out there had to replace your fuel injectors on your Lt4? If so what brand did you use and where did you get them from? I have searched the internet over trying to find 28lbs injectors with no success.
Nov 19, 2022 | 06:16 AM
Finalist 2020 C4 of the Year - Modified
Nov 20, 2022 | 11:27 AM
Racetronix or South Bay Injectors in NY. SBI are really good to deal with. I had my friend drop off injectors in morning and they were shipped to my by 2pm same day .
Nov 20, 2022 | 11:29 AM
Nov 20, 2022 | 11:39 AM
Nov 23, 2022 | 02:06 PM
Every thing on the Internet says they are 28 lb injectors but the programming downloaded from my ECU is set for 27 lb.
Nov 23, 2022 | 03:15 PM
I also looked at the tables from a stock Grand Sport that I have. 27 lbs per hour is what is in the tables. There is another table that has display rate of 4.66 gals per hour, which converts to 28.75 lbs per hour.
http://convert-to.com/conversion/flo...r-hr-flow.html
Dec 5, 2022 | 12:11 AM
Thanks for your help. I didn’t know what I was going to do, but fuelinjectorconnection.com came thru.
Dec 5, 2022 | 01:52 AM
Quote:
Originally Posted by
SBell
Nice! What year is your LT4?
Dec 5, 2022 | 06:16 AM
John Dirks Jr
LT4 is a one year only engine in the Corvettes, 96 & 97 in Camaros & Firebirds
Unless it has been swapped in of course, in which case it needs its '96 tuning to run optimally
