94 corvette backfiring after optispark change
Old Nov 28, 2022 | 03:32 PM
lt1with_balls's Avatar
lt1with_balls
Default 94 corvette backfiring after optispark change
94 corvette backfiring after optispark change. I noticed that the shaft has a notch and only goes on one way but what else could it be? I also replaced the icm with a cheapo from Amazon and installed an msd blaster coil. Might try and put those back? I don’t know what I did wrong
Old Nov 28, 2022 | 03:38 PM
vetteLT193's Avatar
vetteLT193
Are you sure you got the plug wires in the right spots?
Old Nov 28, 2022 | 03:48 PM
lt1with_balls
the optispark only goes on one way though right?
Old Nov 28, 2022 | 03:54 PM
bjankuski's Avatar
bjankuski
The opti only goes one way but the plug wires could be switched around.
Old Nov 29, 2022 | 01:24 PM
lt1with_balls
ok I rerouted the spark plugs correctly. I drove it alil and rumpled on it a few times and now it dies on me. I unplug the ecm and plug back in and it starts for 5 secs then dies…
I really don’t know what it is… could it be fueling?
To 94 corvette backfiring after optispark change
