85 Fuel lines
Old Nov 28, 2022 | 08:29 PM
johnfin's Avatar
johnfin
Default 85 Fuel lines
There are 2 fuel lines on the right side of the front frame rail. Is the lower line pressure or the return line?
Old Nov 29, 2022 | 02:37 AM
stew86MCSS396's Avatar
stew86MCSS396
From: Liliha Bakery stuffing my face with coco puffs!
Seem to recall the earlier l98s had 2 different size fittings, larger being the pressure side. Later years both fittings where the same. Idk seems like a 2 second prime from the ecm should be enough to determine which is which.
Old Nov 29, 2022 | 09:25 AM
johnfin's Avatar
johnfin
Building car from scratch so I can perform that test at this point. Someone cut the upper line which I believe is the one with the filter and pressure. Are hose clamps and rubber hose enough to hold the fuel pressure or is the pressure to great for that?
Old Nov 29, 2022 | 12:15 PM
vinco's Avatar
vinco
Way too much pressure for clamps and rubber hose unless the hard line is flared properly and you use fuel injection rated hose.
Old Nov 29, 2022 | 06:55 PM
johnfin's Avatar
johnfin
Well you mention WAY too much pressure BUT the pressure line coming out of the pump at the sending unit has a rubber hose and clamp. I see alot of high pressure fittings and
hoses in the system but when it comes to that point its a hose clamp.
Old Nov 29, 2022 | 11:15 PM
vinco's Avatar
vinco
The key there is the factory flared hard line and the fuel injection rated hose. You mentioned that the original fitting was cut off, so that tells me it's most likely a plain end and not properly flared. 46 psi will blow any hose right off the end of a plain, straight line. It can work if the hard line is flared.
Old Nov 30, 2022 | 07:24 PM
AZSP33D's Avatar
AZSP33D
Idea: Run -8AN PTFE line with braided nylon and braises steel, all the way from the pump fitting to the fuel rail, and install a -8AN filter in line at original filter location. I think it's about $60-80 for lines/fitting. Do not use non-ptfe for fuel.
Old Nov 30, 2022 | 09:41 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
an 86 i had had copper line ran and connected to the old steel line with rubber. there was no possible way for it to be blown off from 40psi. that small stretch of rubber line had cracked and was leaking however. scared me one day came into shop an was a serious gas odour.
carefully cut new fuel grade rubber line to length and had my wife ready with fire extinguisher. wasnt a big deal and i tracked that car. i cut the line longer for more overlap and doubled up the clamps.
im not saying do it but in a pinch it works
To 85 Fuel lines
