Underdrive Pulley Question
Old Jan 10, 2003 | 10:15 AM
flynhi's Avatar
flynhi
Default Underdrive Pulley Question
I'm converting the L-98 in my 71 to serpentine and will be replacing all the v groove pulleys with serp pulleys. Is there a significant advantage to underdrive pulleys such as those sold by March? Most of my driving is in town in the 2000 to 4000 rpm range.
Old Jan 10, 2003 | 10:46 AM
jmrl98's Avatar
jmrl98
Default Re: Underdrive Pulley Question (flynhi)
I bought the crank/alt pulley set from TPIS for my '85 L-98. They are March pulleys, and I've had no trouble with them. I can only compare them to stock, and they improved low end throttle response in comparison. With all the beef you've got going, I'm not sure if they will help any or just serve the normal application. :seeya :cheers:
Old Jan 10, 2003 | 10:55 AM
john25's Avatar
john25
I agree, they work. :yesnod:
Old Jan 10, 2003 | 11:22 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
I use the 3 pc. pulley system from March.....only problem was voltage drop charging from the alt., had to get a different pulley from March.....
Now the system works great with no drop in voltage when using accessories or ideling. Also getting the right lenth belt was a small hassle....worth it though...
Happy with the system, and even looks great.....
tony
:steering:
[Modified by oldace84, 11:24 AM 1/10/2003]
[Modified by oldace84, 11:26 AM 1/10/2003]
Old Jan 10, 2003 | 12:41 PM
GusBustamanteJr's Avatar
GusBustamanteJr
Default Re: Underdrive Pulley Question (oldace84)
I use the March 3 piece. I like the extra zip it gives in the SOTP feel. It doesnt affect my voltage BC I am running an LT1 alternator.
Old Jan 10, 2003 | 02:23 PM
vetteguy216's Avatar
vetteguy216
Default Re: Underdrive Pulley Question (GusBustamanteJr)
You will always get that voltage drop. But it shouldn't cause any problems the only thing that will happen is the headlights will dim a little. If you dont have a high output sound system there should be no prblem.
Happy modding! :cheers:
Old Jan 10, 2003 | 06:54 PM
flynhi's Avatar
flynhi
oldace,
Any chance you would have part numbers for the March set with special alternator pulley?
Old Jan 10, 2003 | 07:19 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Unless you have a very high output alt, get the March Power & Amp pulley series. It has an underdrive crank pulley and an overdrive alt pulley to maintain stock alt speeds.
Old Jan 11, 2003 | 09:41 AM
flynhi's Avatar
flynhi
Default Re: Underdrive Pulley Question (65Z01)
ttt
Old Jan 11, 2003 | 02:50 PM
h rocks's Avatar
h rocks
I had a two piece pully set on my '91 B4C Camaro. Affected my voltage bigtime, as well as my low speed power steering. I ended up just running the crank pulley. Didn't notice any drop in power. Still ran a high 13.
Old Jan 12, 2003 | 06:06 AM
Zora's Avatar
Zora
Cruise-In I Veteran
Save your $$$...dyno tested. :yesnod:
To Underdrive Pulley Question
