94 corvette no downshift
Old Dec 2, 2022 | 12:13 AM
lt1with_balls's Avatar
lt1with_balls
Default 94 corvette no downshift
I have to manually shift in to a lower gear to do this but I’d like to be able to fix this… is it a cable? Or something?
Old Dec 2, 2022 | 08:57 AM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
Sounds like your car is ready for the junkyard.
There are 2 scenerios here.
1. you purchased a car that is has so many issues, it is beyond your ability to fix it and is strictly a money pit
2. you are trolling the forum. none of the issues has a resolution, and when folks asked you about it, the question was ignored.
every couple days there is something new.
All since you joined 11-10-2022.
So far:
No heat 94 vette
No power at all completely dead corvette
Car has trouble starting and is misfiring
94 Corvette very rough ride (like riding on wooden wheels)
No heater 94 corvette
Oil in optispark shaft insert(leak?)
94 corvette backfiring after optispark change
Wobble and squeky noise in passenger rear wheel shaft/ suspension
94 corvette misfiring and then after 20 mins of driving it losing power and backfirin
94 corvette rear rattle knocking noise ( like fiberglass or plastic noise)
94 corvette loud slam into gear from park.
94 corvette starter issue
