TV cable removal 93 AUTO trand
But I think, there is a bolt on the tab where the cable goes into the transmission.
I believe you take it out, and you can raise the cable housing enough to disconnect from the transmission.
You may have to remove the pan to disconnect the cable, but again, hopefully someone else pops in here to answer.
Two other pointers I wanted to mention.
1. Be careful with that cable. It is no longer available for for the 92-93.... at least as I could find. Its one assembly with the other cables, and ties to the ASR rather then the throttle body as most cars would have.
2. Be sure to intall the dipstick tube before installing the transmission. I dont think there is a way to fish that thing in there once the transmission is in place. And I tried....
