Needs shocks
Old Dec 13, 2022 | 12:47 PM
Macaroni Kid's Avatar
Macaroni Kid
Default Needs shocks
Finally getting to drive my father's 89 convertible after doing the fuel system and she's running good. The ride is less than desirable and is comparable to driving one of my old trucks, the tires have maybe 1000 miles, but are ten years old, not cracked, but have hardened I guess, I know I need to replace. Shocks are original Bilstein Z51 package and the front does the ol' 2-3 bounce-back when pushing down hard on the front. I want to replace shocks first then tires eventually. Will there be a major improvement doing only shocks? ball joints and steering components are nice and tight too. Are there other suspension components I'm overlooking?
Thanks, Mike
Old Dec 13, 2022 | 02:36 PM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
​​​​​​​ I want to replace shocks first then tires eventually.
driving on 10 year old tires could put you into a position where replacing the shocks is a mute point. if money is a real concern, find a set of el cheapo shocks that will fit.
for example autozone has some for $33.00 each
​​​​​​​https://www.autozone.com/suspension-...01b/188074_0_0
Old Dec 13, 2022 | 03:14 PM
Macaroni Kid
It never ends...Well they both need replacement then, soooo... another case of "while I'm here, I might as well replace..."
Old Dec 13, 2022 | 03:39 PM
drcook's Avatar
drcook
True, you just want to concentrate at first on what will kill you or wreck the car. You can run some throw away shocks for a bit to be able to afford tires first. I would also look at the brake pads and bleed the brakes. Run enough fluid through to purge the system. A couple bottles of brake fluid are cheaper than an insurance deductible or ticket. :-)
Bilstein shocks are $100'ish each
https://www.zip-corvette.com/84-96-c...in-shocks.html
cheap shocks will work for a bit
there have been plenty threads recently on tires, use the search function, will give you a good education
Old Dec 13, 2022 | 04:40 PM
C44EVR's Avatar
C44EVR
I'm in a similar place with my '96, 7-8yo tires.
I replaced the factory-original shocks last month (27yo) on all four corners with the Bilstein B8s and the difference was amazing. Then I replaced the bushings in the rear with the SuperPro set, and it improved still further--really drivable. Going to do the fronts soon, big project. You'd be surprised what those bushings look like when you get the control rods and strut rod off, after all those years, if your car is wearing the originals. That rubber gets hard over three decades.
But those tires are still killing me, hard and noisy. And they're not as old as yours. My rationale for doing the tires last is that I want the suspension to be sorted and aligned first--but I might have felt more urgency if they were 10 years old, there's a point at which it becomes a safety issue, and the line is a little fuzzy [at least to me].
So, sorry to say, all of the above. But take it one thing at a time--each of these things will almost certainly improve the ride and handling somewhat. Based on my recent experience, if I was starting over today I think I would pursue the same order: shocks, bushings, then tires.
Old Jan 22, 2023 | 02:14 PM
Macaroni Kid
A little update...did shocks a week ago and made a MAJOR improvement, Bilstein Z51's all around, brakes next, have drilled and slotted rotors with pad kit waiting to go on. Headlight repair kit also waiting on the bench.
Old Jan 22, 2023 | 07:39 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Please don't delay on the tires. A 10 year old tire may blow out and you will have HUGE problems. You comfy ride wont matter then.
Old Jan 22, 2023 | 08:08 PM
car addict's Avatar
car addict
I agree with the tire guys. I can't change what you've already done, but I can encourage you to do tires next.
To Needs shocks
