MAP testing
Old Dec 14, 2022 | 09:51 AM
johnfin's Avatar
johnfin
Default MAP testing
Can a MAP sensor on the side of the throttle body be tested with a volt meter?
Old Dec 14, 2022 | 11:49 AM
AZSP33D's Avatar
AZSP33D
They're usually located on the intake manifold... on the 1985-1996 throttle body, you have the IAC and TPS. Forward you may have an IAT.
Old Dec 14, 2022 | 05:56 PM
Mrvettenick's Avatar
Mrvettenick
If it's on the throttle body, do you mean the TPS Throttle Position Sensor? It can be tested.
To MAP testing
