Abs asr issues
Old Dec 18, 2022 | 08:28 PM
Papichulo's Avatar
Papichulo
Default Abs asr issues
1993 c4, 100,000 miles on it. Random abs pulsating when pulling up to a stop light in gear while stopped. I can feel it mostly in the gas pedal, almost to the point where I can’t even push the pedal at all(a lot of resistance) and the car starts idling rough. If I put it into neutral the symptoms stop. Need help
Old Dec 18, 2022 | 09:14 PM
Papichulo's Avatar
Papichulo
Just read the codes and I have a H66 in the abs module
Old Dec 19, 2022 | 05:07 PM
jph46's Avatar
jph46
DTC 66 is “Adjuster Assembly Control Malfunction “ make sure all the cables are not binding, I can copy the info from the Service Manual if you don't have one.
Old Dec 20, 2022 | 05:53 PM
Papichulo's Avatar
Papichulo
That would be great if you could. I do not have them
Old Dec 20, 2022 | 07:50 PM
Papichulo's Avatar
Papichulo
I will check that out. Thanks for your input.
Old Dec 21, 2022 | 09:34 AM
Papichulo's Avatar
Papichulo
Third brake light working as it should!
Old Dec 21, 2022 | 09:31 PM
jph46's Avatar
jph46
Here’s theDTC 66 check list. There is also a great utube video at Ozzstar Corvette, on adjusting the asr motor and cables.
Old Dec 21, 2022 | 09:55 PM
Papichulo's Avatar
Papichulo
Thanks for this info, I will do this when I get back to work on Tuesday. I did see that video that ozz did in asr adjustment. Is there a possibility that the asr cables being adjusted can correct my issue?
Old Dec 21, 2022 | 11:54 PM
jph46's Avatar
jph46
Not sure, but it might tell you if anything is binding. Had a DTC 65 code on mine, did try the reset, didn’t help. My issue was a bad EBTCM. Good luck, hope you get to the bottom of this.
Old Dec 30, 2022 | 02:50 PM
Papichulo's Avatar
Papichulo
Watched the video on asr adjustment from ozzcorvette. Performed the procedure this morning and it corrected my issues. Thanks again!
Old Dec 30, 2022 | 03:00 PM
jph46's Avatar
jph46
Great,,glad you got it fixed.
To Abs asr issues
