My 1988 Corvette smokes very black
My 1988 Corvette smokes very black, I made a capture with WINALDL and I don't understand anything about the registered table. Is there a good soul who can read the board to explain to me what is wrong? Thanks for any help
Currently, appears playing around with the ECU/ prom.
Major problem.
(1) "MALFFLG4:51 CAL Pack missing"
Hence. WINALDL txt attached.
More DTC codes than a math formula.
Michel Neusy (12-26-2022)
On your other post you stated that you replaced the injectors with 24 lb ones, the 1988 used 22 lb, and that your fuel pressure was a little low.
Will this cause an issue ? That I don't know but if you are chasing an issue with a malfunctioning FPR and the wrong size injectors you could follow erroneous diagnostic paths.
Do you speak English or are you running everything through a translator, such as the one you posted earlier when you joined the forum.
Have you tried doing the sniff check on the fuel pressure regulator vacuum hose?
Not sure what's going on with your datalog...just know that the BLM/INT never move from 128 and the O2 volts start ~.800mv and climb closer to ~900mv. This tells me that the ECM never comes out of open loop which if your injectors are too big to begin with, the ECM is not making any adjustments to compensate. It's going to fuel based on feedback from the CTS.
Edit:Idk why I didn't think to look at your coolant temp sensor (CTS)...winALDL is reporting (assuming Fahrenheit as my other logs report as such) 13dF at the start of the log and after 5 minutes of run time gets up to 52dF. I would consider taking a ohms reading on the CTS.
...also you can forego the DVM and connect to winALDL (ignore that I have it on 1227747, yours should be on 1227165). Navigate to the sensor data tab. While there, check the error tab as well and report back with any codes.
Sorry I understood the CTS, it's the temperature sensor I guess. In Belgium we speak of CTN or CTP for a resistor with a negative or positive temperature coefficient.
but I thought the ECM would make up the difference
https://www.pcmofnc.com/
reprogram chips on the earlier C4 Corvettes for when you change things that the ECM needs to know about. As long as the crankshaft is the same stroke, that is not something that would affect the ECM's calculations. Different size injectors does. It is trying to fuel the car based on 22 lbs, so the 24 lb ones inject more fuel causing the fuel mixture to be rich. Bigger ones would cause more issues of course. Also if your fuel pressure is not what GM programmed the ECM to expect, it is seeing feedback from the O2 sensor and trying to adjust the mixture based on what it was programmed with originally.
Major problem. (1) "MALFFLG4:51 CAL Pack missing" With a fault like that I think my ECM is screwed. At RockAuto they have just returned a CARDONE 776571 programable ECM which is suitable for my car with shipping and customs costs it will cost me 220€ is this a good idea? Did I understand everything correctly? Knowing that I will have to find a custom program to put in and that I have lost the address of someone who made the custom program?
This is where I found that the stock size was 22 lbs.
https://tech.corvettecentral.com/201...lection-guide/
Did you make sure that the main wiring harness was plugged in correctly and that the replaceable chips in the ECM are pressed down firmly ? If you open the ECM housing make sure that you touch something metal (such as a bracket on the engine) to discharge any static electricity in your body.
As I've mentioned before about the coolant temperature sensor, can you verify if winALDL is using Fahrenheit or Centigrade? On one of my screenshots, it will show you both. If it indeed is using Fahrenheit, then 13*-52*F is probably too cold for your region and I would suspect a faulty coolant temperature sensor. This alone could be preventing the ECM to go into closed loop. The only other flags I see are relating to running rich.
Another noteworthy item is idle air control and throttle position appear to be high but high iac maybe normal on a cold engine.
Edit: Found out if you save the txt document as an xls. It is much more readable!!! Ignore the RAW data as none of it is converted to sensible data. Helps when you read JoBy’s notes.
I go through a translator, I rechecked the fuel pressure: 24psi, mounted a new lambda probe, mounted a 30Hz 5v circuit with a NE555 for the VAT and an operational amp for the data because if I had the signal with an oscilloscope but when I plugged in the test cable the data signal disappeared. Now I know how to read the signal.
I believe that means nothing. If you are opening the datalog with a text editor, the first 2 lines are the header for the parameters/sensors. Why it wraps around to second line is beyond me. "MALFFLG4:51 CAL Pack missing" is nothing more than a header and the corresponding data column is reporting all zeroes. At the start of the 3rd line, this is where the data starts and unfortunately it doesn't line up well with the header.
That's weird in your other thread you had 40 psi but now you have 24psi or did you mean you have 24 lb /hr injectors. If you're only getting 24psi and the rich condition persist, I'd suspect the fuel pressure regulator diaphragm leaking fuel into the intake plenum.
I mounted 24Lbs because I couldn't find 22Lbs and I thought the ECM was going to compensate with the lambda sensor.
Michel Neusy (12-27-2022)
Or any other size injectors.
You can kinda, cheat. If you have an adjustable regulator.
System working perfect.!
Remove a few pounds to compensate injector difference. Not recommended. Pulse, and related info almost guaranteed different.
OE injector parameters are locked into the PROM. You are forced to pull the prom and update the constants table.
At this point.
Near same price. a tune. will net you 40HP. Night and day difference in performance, efficiency, response, MPG.
I just found on the net that the 0280 150 943 injectors that I was sold for 24 lbs only do 18.25 lbs/h! How come the car smokes very black with undersized injectors? I'm thinking of replacing them again (mounted in July 2023) Do you know a place to have them not too expensive but with 4 holes and not 1 like the original?
Your system needs to be perfect before. All else.
You have multi posts. I believe 1 post. You provided 40lbs. pressure at rails. Another post. 24 is in question. 24lbs injectors VS pressure at rail.
Voluminous codes stored in the ECU. Sampled from your posted. WINALDL.
1=antithef module
2=alim 12V/5V
3= op amp
4=+5v/-5v converter
5= 12V key on
