Resonator Elims???
Old Jan 11, 2003 | 01:41 PM
JADVette94's Avatar
JADVette94
Default Resonator Elims???
I read a lot about muffler elims and how there is a possible low end power loss. I am wondering if there would be a power loss on a 94 LT1 if the resonator was removed and the mufflers left on? RichardG has done this and appearantly likes the sound. I am considering just welding in straight pipes where the resonator is now since my resonator has developed a rattle. Any problems with this? :confused:
Also, my brother has advised me to put a crossover pipe in as well. Is this necessary, or advised?
Thanks for any help. I am trying to fix a corvette with suggestions from my otherwise MOPAR musclecar family. :nonod:
[Modified by JADVette94, 6:54 PM 1/11/2003]
Old Jan 11, 2003 | 04:11 PM
BIG JIM 54's Avatar
BIG JIM 54
Default Re: Resonator Elims??? (JADVette94)
Hi JAD,
I eliminated my resonators on my '87 with the Mid-Am kit. I can't say it made it run any better really but certainly not worse. It does sound really cool now and the back end view that other drivers see behind you is vastly improved. I painted the pipes with Hi-temp flat aluminum paint and the surrounding panels with Krylon semi-flat black. Looks REALLY good, IMO.
I can't comment whether or not the performance issues apply to your '94 however. I don't know so judge for what it's worth.
BIG JIM
Old Jan 11, 2003 | 04:29 PM
owensLT4's Avatar
owensLT4
Well here goes. I had a 96 LT1 and put on flowmaster mufflers. Car ran good and sounded pretty good. Other mods were cold air box, air foil, and changed shift points and firmness. I would run very consistently 13.8 @ 102.
THEN, I took off the resonator off and installed straight pipes in its place. The sound was great. Took it to the track expecting 13.5 @ 105. NOT!! Could not break 14.0 and never got it over 100 and that was only once at 100. Put resonator back on (thank god I didn't throw it away) and 13.8 and 102 was back. That's my story. Italked to a local tuner and he said when I removed the resonator I lost about 30 hp. I AM A BELIEVER!!
If all you are looking for is sound then go ahead but just remember your are losing HP.
Owen
Old Jan 11, 2003 | 04:51 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Guys stay tuned for a test I'll be conducting shortly.
I will be trying out the JCL Spiral Baffles in place of the resonator.
If this test proves positive, there will be a group purchase of them most likely from ECS.
Old Jan 12, 2003 | 08:27 AM
BIG JIM 54's Avatar
BIG JIM 54
Default Re: Resonator Elims??? (owensLT4)
Hi Owens,
I'm wondering if the stock chip just doesn't like exhaust changes. I know I didn't loose 30+ HP. That much loss in performance all at once you would certainly feel without taking it to the strip. Maybe my ADS chip made the right changes to the A/F to compensate. Maybe my cam liked a more open exhaust. Or maybe the '96 stock ECM is more complicated not liking exhaust enhancments. I can't say for sure if I gained or lost a small amount of HP but not enough to feel either way by eliminating the resonators.
[Modified by BIG JIM 54, 1:28 PM 1/12/2003]
To Resonator Elims???
