85 TPI Barebones starting
Old Jan 7, 2023 | 02:59 PM
johnfin's Avatar
johnfin
Default 85 TPI Barebones starting
What is the min. wiring and parts I need to start an 85 C4? I was thinking 1.inside the car-wiring to the (a)computer the(b)ignition and to (c)fuel pump, no instruments connected) 2. outside -The (d)MAF, (e)o2, (f)injectors, (g)burnoff, (h)IAC, (i)Throttle position, (j)vacuum for pressure regulator, (k)HEI connected.
Anything else I am missing?
Old Jan 8, 2023 | 12:12 AM
jdjenk's Avatar
jdjenk
Youll need coolant temp or its fairly unlikely itll start.
Old Jan 8, 2023 | 08:34 AM
johnfin's Avatar
johnfin
Is that the one on the drivers head or the front of the intake manifold?
Old Jan 8, 2023 | 09:31 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Front of Intake.
To 85 TPI Barebones starting
