Block question
Old Jan 11, 2003 | 07:05 PM
BAdAzZV8's Avatar
BAdAzZV8
Default Block question
I am going to add a blower to my current setup, and am going to buy another block to build up so I can just swap it in. I was wondering if I should get the 4 bolt or the 2 bolt. I know you can splay the cap on the 2 bolt and make it stronger than the 4 bolt, but how much hp can each setup handle(2 bolt, 4 bolt, 2 bolt splayed)?
Old Jan 11, 2003 | 08:06 PM
Monks's Avatar
Monks
Default Re: Block question (BAdAzZV8)
With a blower, I would use splayed 4-bolt caps. I bought a 2-bolt
block out of an f-body and installed 4-bolt spayed caps for about
$450, including the caps.
Russ
Gainesville, FL
Old Jan 11, 2003 | 08:35 PM
95AquaC4's Avatar
95AquaC4
Default Re: Block question (Monks)
Splayed stronger than standard 4-bolt? Hmmm. learn something new everyday! :D
Old Jan 12, 2003 | 02:11 AM
BAdAzZV8's Avatar
BAdAzZV8
Default Re: Block question (95AquaC4)
hey monks, how much hp are you pushing?
Old Jan 12, 2003 | 02:53 AM
Light84vette's Avatar
Light84vette
I would have to say a High Performance engine would have to use 4 bolts, thats a must, how are you building your engine? Are you going 383 or BIG BLOCK??? :rofl: :rofl: :rofl:
Old Jan 12, 2003 | 09:43 AM
Monks's Avatar
Monks
The outside bolts, when splayed, anchor into a stonger part of the
block. From what I understand, more load is spread to the outside main
cap webbing. I would guess that all aftermarket "race" blocks have them.
In my case, The increased cost of adding splayed caps was partially
offset by using a less expensive, and easier to find 2-bolt block. ($150)
A great mod for people needing a very strong bottom-end... Hi-Revers,
strokers, and blown motors.
Russ
Old Jan 12, 2003 | 09:56 AM
Monks's Avatar
Monks
Not enough! :lol:
FYI, I will have the car at the NCCC Corvette show next Saturday
(Jan 18th) at the Thornbrook Shopping center on 43rd St. in Gainesville.
Russ
Old Jan 12, 2003 | 11:32 AM
vader86's Avatar
vader86
id use the 4 bolt
Old Jan 12, 2003 | 01:42 PM
BAdAzZV8's Avatar
BAdAzZV8
Default Re: Block question (vader86)
id use the 4 bolt
And is there a reason you would do this?
[Modified by BAdAzZV8, 1:42 PM 1/12/2003]
Old Jan 12, 2003 | 01:47 PM
BAdAzZV8's Avatar
BAdAzZV8
Default Re: Block question (Light84vette)
Oh, and no big block and no stroker motor. I already have a vortech s/c to put on, but I want to forge the bottom end and maybe put a head/cam package on it after I get the bottom end done.
Old Jan 12, 2003 | 04:07 PM
cprgmr's Avatar
cprgmr
Ummm... If you're going to take your motor out to do a forged bottom end, why wouldn't you go to a 383? I've done a little research (going to do a top-end and a 8psi ProCharger) and from the conversations I've had, a blown 383 makes awesome power! :)
Old Jan 12, 2003 | 08:26 PM
Light84vette
Default Re: Block question (cprgmr)
I would have to agree, go all out if your going to forge everything. ALso If your going to forge all the parts, then you might as well go 383 and low comopression like 8.5 to 1, Then that way you could up the boost whenever you want or if you change your SC you could run more boost and make more power. This way would save you money b/c you wouldnt need to buy more parts to handle that power or get lower compression pistons b/c you already have them :yesnod:
Old Jan 12, 2003 | 11:51 PM
BAdAzZV8's Avatar
BAdAzZV8
hmmm, something to think about then.
[Modified by BAdAzZV8, 11:52 PM 1/12/2003]
Old Jan 13, 2003 | 12:36 AM
Light84vette
Yeah, then you'll have a really BADDAZZ V8 :lol:
Old Jan 13, 2003 | 12:38 AM
Light84vette
I'd say with a 383CID SBC and with some high flow heads, intake and exhuast with a 15-17psi SC, I think you'll be able to reach the 650HP Mark eaisly. :yesnod: :yesnod:
Old Jan 13, 2003 | 12:29 PM
BAdAzZV8's Avatar
BAdAzZV8
Well I am going to have to do some research on a 2 bolt splayed to 4 bolt 383 now. :cheers:
Old Jan 13, 2003 | 01:25 PM
388 SOLid RoLLeR's Avatar
388 SOLid RoLLeR
Go with the 4 bolt. Splaying the 2 bolt is not a good idea. The splay pulls at parts of the block and can actually distort the block, kinda like flexing. cant remember exactly what my tuner was saying about the 2 bolt and splaying but he said stay away. 4 bolts are in demand for a reason. :)
:cheers:
Old Jan 13, 2003 | 03:00 PM
Monks's Avatar
Monks
Default Re: Block question (388 SOLid RoLLeR)
:cheers:
Absolutely Wrong!!!!! Splayed caps are the strongest way to go, and
they do not distort the block. Talk to any good race engine builder, and
they will recommend splayed caps for the strongest bottom-end.
Russ
To Block question
