85 engine oil cooler
Old Jan 11, 2023 | 08:16 PM
johnfin's Avatar
johnfin
Default 85 engine oil cooler
Was this standard or an option?
Old Jan 11, 2023 | 08:20 PM
WVZR-1's Avatar
WVZR-1
An 'option' that is generally thought, given newer/different quality of lubrication products would be better to eliminate than to retain or add.
Old Jan 12, 2023 | 11:55 AM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
The oil cooler was a factory option.
Old Jan 12, 2023 | 12:18 PM
Joe K's Avatar
Joe K
2022 C4 of the Year Finalist - Unmodified
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (appearance mods) 2019
Have you decoded the spid (service parts identification) label. It's located in between the bins behind the seat's. It will have a lot of alpha numeric codes on it. Here is one of my base coupe and here's a link (under pic) to decode them.
RPO Codes
My guess is the car is a Z51 (it will be on the spid) or one of the variants as they came with oil coolers.
HTH,
Joe K
Old Jan 12, 2023 | 10:46 PM
FOURSPEEDVETTE
Originally Posted by IHBD
In 1985, KC4 Engine Oil Cooler was included with V08 Heavy Duty Cooling. Z51 included V08. (I believe that B4P Radiator Boost Fan was also included in V08, but I am not sure about this.)
There were 17,539 V08 of which 14,802 were included with Z51, so there were 2,737 KC4 on non-Z51 1985's. There were 39,729 1985s, so 22,190 1985s did not have KC4. KC4 was not a popular stand-alone option in 1985. Joe is correct with his assessment that if an 85 has a KC4, it probably is a Z51 because there were only 2,737 stand-alone V08s.
My 85 has the factory Heavy Duty Cooling System with Boost Fan and the Oil Cooler. It does not have the Z51 Suspension system. So, I understand there were only 2737 built like this?
Old Jan 12, 2023 | 10:50 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
generally! but it sure makes a difference on track 👍. wouldnt give mine up.
To 85 engine oil cooler
