85 voltage regulator
Old Jan 12, 2023 | 07:17 PM
johnfin's Avatar
johnfin
Default 85 voltage regulator
Where is the voltage regulator located?
Old Jan 12, 2023 | 08:08 PM
s carter's Avatar
s carter
Inside the alternator, I feel with what you have asked and done to replace is within your capabilities If you need to replace it.
It's actually kinda fun to replace, you split the case things go pop and fly. You think great now what. No big deal as long as you have a WD-40 spray tube to cage the brushes then everything falls back together.
https://www.oreillyauto.com/detail/c...corvette?pos=0
Old Jan 12, 2023 | 08:09 PM
LiveWire1's Avatar
LiveWire1
It's all contained in the alternator.
To 85 voltage regulator
