Which DOT
Old Jan 20, 2023 | 07:47 PM
johnfin's Avatar
johnfin
Default Which DOT
When adding new clutch parts to my 85, which fluid, 3, 4 or 5?
Old Jan 20, 2023 | 10:03 PM
84 4+3's Avatar
84 4+3
Dot 3 or 4... dot 4 has a higher boiling point. Dot 5 is silicone... you could use Dot 5.1 which is compatible with 3/4. I'd use Dot 4 as it's available pretty much everywhere and inexpensive.
Old Jan 20, 2023 | 10:11 PM
Blue Bucket List's Avatar
Blue Bucket List
In a clutch application I think 3 would be fine as not much need for higher boiling point there. Also, 3 is less likely to absorb moisture than 4 from what I have read. If you are thinking of a brake flush also than it would be best to do both with the same and have less chance of a half empty bottle sitting around absorbing moisture.
Old Jan 21, 2023 | 08:50 AM
phaze426's Avatar
phaze426
When we replaced the hydraulics on my son's, we went with one by Valvoline labeled as "Synthetic DOT 3 & 4." I had read somewhere that it's what Bill Boudreaux recommended. It's seemed to work alright for us, though we're admittedly not using the car in a very demanding way where we'd have to worry about burning/boiling the hydraulic fluid.
Old Jan 21, 2023 | 12:24 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
I don't think anyone has to worry about overheating clutch hydraulic fluid.
Old Jan 21, 2023 | 01:23 PM
LiveWire1's Avatar
LiveWire1
In my 85 4+3, I put Dot 5 silicone brake fluid in the clutch system. It doesn't attract moisture, so it's good for a long time. The 85 doesn't have ABS, so I put it in my brake system as well. DOT 5 Silicone foams with ABS brakes.
Old Jan 21, 2023 | 02:13 PM
Blue Bucket List
If you do decide to go with 5 be sure that you flush the system well as 3 and 4 don't play well with 5.
To Which DOT
