headlight relays
Old Jan 12, 2003 | 05:20 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
Default headlight relays
I know this is probably a stupid question, but how are you supposed to get the headlight relays on an 86 out without destroying them or the plate they're screwed into?
Old Jan 12, 2003 | 05:29 PM
BIG JIM 54's Avatar
BIG JIM 54
Default Re: headlight relays (flyersfan1088)
The 3 headlight relays are R&R'd as an assembly, plate and all.
BIG JIM
Old Jan 12, 2003 | 05:44 PM
flyersfan1088
Default Re: headlight relays (BIG JIM 54)
Passenger side headlight door doesn't come up. How do I test the relays? If that is the problem, any idea how much the new assembly costs?
Old Jan 12, 2003 | 06:13 PM
jfb's Avatar
jfb
First check to see if the 2 screws on each side of the headlight cover haven't backed out. Next, unplug the headlight motor and jump 12 v to the green wire (positive) and the grey wire (negative), the headlight door should open. These colors are from my 87 manual, so if your wire colors are different, you have three wires to apply 12 v to, two at a time. You cannot hurt the motor with a wrong connection. You can also put a voltmeter on the unplugged wiring harness connector going to the headlight motor. When the headlight switch is on, then 12v must be across the green and grey wires. A small 12v lamp can also be put across these two wires and it should light with the headlight switch turned on.
Old Jan 12, 2003 | 08:40 PM
flyersfan1088
Default Re: headlight relays (jfb)
Thanks for the info. I'll give it a shot tomorrow and keep my fingers crossed that it's the relay and not the motor
To headlight relays
