spare tire 84-87
Old Feb 4, 2023 | 05:32 PM
johnfin's Avatar
johnfin
Default spare tire 84-87
Whats the largest spare tire that will fit into the holder or are we stuck with the specialty space saver.
Old Feb 4, 2023 | 05:43 PM
WVZR-1's Avatar
WVZR-1
Measure and let us know!!!!
Old Feb 4, 2023 | 07:00 PM
johnfin's Avatar
johnfin
Really?
Old Feb 4, 2023 | 07:46 PM
FostersPerformance's Avatar
FostersPerformance
Its designed to hold the full size tire you took off.
Old Feb 4, 2023 | 08:32 PM
johnfin's Avatar
johnfin
Default Tire
I wish it was that easy. Iam building the car from scratch and dont have a spare.
Old Feb 5, 2023 | 06:08 PM
JoBy's Avatar
JoBy
This is the best picture I found now. You see the front hinge for the tray, and the slot on the tray side. You can drop the tray to a lower position to fit a full width tyre, or use the upper position for a space saver tire.
The rear fastening bolt also haev an upper and lower anchor point.
In the lower position the tray will be very visible from behind.
There is also some adjustment possible on the threads, so a slightley wider tire can me made to fit with the tray in the upper position.
Old Feb 5, 2023 | 07:38 PM
johnfin's Avatar
johnfin
Default Spare
Thanks for the great info and pics. I guess iam looking for an easy answer like use one from a 4th gen firebird or something like that so i can pick one up in the junk yard. C4s are always missing spares in the yard.
Old Feb 5, 2023 | 11:35 PM
ACMX92's Avatar
ACMX92
2026 Restomod of the Year Finalist
2026 Corvette of the Year Finalist - Modified
2025 C4 of the Year Winner - Modified
2021 C4 of the Year Finalist - Modified
I bought one of these. https://modernspare.com/product/1984...e-kit-options/
Kind of pricey and overkill but I wanted something that would clear any future big brake kit. I have heard 04-06 GTO spares will work with the right hubcentric adapter but I can't say I know a ton about that.
Old Feb 6, 2023 | 11:58 AM
RWDsmoke's Avatar
RWDsmoke
I use a late model Camry spare with an adapter. Tire is the same size as the 88-96 corvette spare and it clears my c5 front brakes. I found a Camry spare cheap and the tire was less than a year old.
To spare tire 84-87
