Has anybody put the 98-01 optional magnesium wheels on their C-4? How does the offset work out? I've got a '95 I want to put them on. Is there any problems with the magnesium wheels? I heard they are soft and easily marked. Thanks.
there should be no problem, i think they're the same offsets and everything as the normal c5 wheels, which fit perfectly on 88 and up c4's. i may be wrong, i've never seen any mags on a c4 and i'm not sure as to the exact dimensions of those wheels, but i think they are identical to the normal c5's as i already said... :D
The offset is very different on the rears I believe, and around 1/4" on the fronts. I may be off on the dimensions, but I do recall bolting up a front and rear HRE's from a C5. Would have required a thick spacer to get them out far enough.
From: Looks like I picked the wrong week to stop sniffin glue Orlando
Re: magnesium wheels (loflite)
Magnesium is brittle, flammable, and expensive, but it’s also extremely light weight. If you’re gonna race, and every ounce counts Magnesium is great.
:chevy
