torque converter
Old Jan 13, 2003 | 05:13 PM
loflite's Avatar
loflite
Default torque converter
Basic question, what does installing a higher stall torque converter do for me? How will the car perform differently from stock. Thanks.
Old Jan 13, 2003 | 05:42 PM
needanother1's Avatar
needanother1
Default Re: torque converter (loflite)
Without going into too much detail, a higher stall converter allows the engine to rev higher, where there's more power available, before it forces the wheels to spin. Its kind of like releasing the clutch on a manual transmission car at a higher RPM. If you use a quality converter and stay conservative on the stall speed, the drivability characteristics won't change much at light throttle. You'll get a more powerful launch (and have more traction problems) under heavier throttle.
Supposedly a stall speed 500-700 RPM below your torque peak will give the best performance. Stall speed is not absolute, but will vary depending on the engine's torque output. The factory converters usually stall around 1400 to 1600. 2000 to 2800 is usually good for street performance.
This is just information I've collected from many sources, and anyone may feel free to correct me if I've said anything wrong.
Yank and Precision Industries make some of the more well-regarded converters. Yank is http://www.converter.cc
Precision Industries is http://www.converter.com
Both websites have a lot of good information!
--Jason
Old Jan 13, 2003 | 06:26 PM
Phil-tha-Rush's Avatar
Phil-tha-Rush
Default Re: torque converter (needanother1)
it doesnt allow the engine to rev higher, but allows it to rev quicker.
an example.....if im riding along at 1600 rmp, and mash the gas, my rpm will instantly go to 2600 rpm, putting me in my power band faster. As the tranny shifts, engine rpm will stay above 2600 rpm, KEEPING me in my powere band throughout the run.
with a lower stall..... say 1400......... the engine has a slower "climb" into the powerband
Old Jan 13, 2003 | 07:07 PM
vader86's Avatar
vader86
The results will show at the track, your launch will be better and your times will drop.
Old Jan 13, 2003 | 07:13 PM
tpivette's Avatar
tpivette
Default Re: torque converter (Phil-tha-Rush)
:eek: WOW! i didnt know it did all that as well! i thought it was only good for raising your launch rpms! man i cant wait for the track to reopen to try my new one!
Old Jan 14, 2003 | 03:54 PM
loflite's Avatar
loflite
Thanks for the info. Can't wait to get the car back from DRM! :)
To torque converter
