C4 Automatic dual caliper brake assembly
Old Feb 17, 2023 | 08:59 AM
Rory Vega's Avatar
Rory Vega
7th Gear
Default C4 Automatic dual caliper brake assembly
I own a C4 automatic with dual caliper BRK-X2 assembly. The brakes work wonderfully, but the pedal goes too low before it starts breaking. The brake master cylinder is standard, I would like to find a brake master cylinder with a bigger bore size or a longer rod from the brake pedal to the brake booster. Any other solution will be gratly appreciated. The car have been stored for 12 years, due to a health problem now over, nearly since I installed the dual calipers assembly; there was an article in amagazine, probably Vette Magazine in that time but I cannot remember. By the way I do live in tha Canary Islands. Thanks in advance for your reply. R. Vega
Old Feb 17, 2023 | 03:34 PM
64Scout's Avatar
64Scout
Are they stock calipers? Or maybe I should ask if you know what they are from. You'll definitely need a master with a bigger bore, since you are now pushing twice as much fluid (I assume)
Old Feb 18, 2023 | 01:31 AM
Rory Vega's Avatar
Rory Vega
7th Gear
Yes they are stock calipers, but the rear ones are from a previous Corvette model to avoid the parking brake linkage, they use the same brake pads. I do understand that the stock master cylinder is a 1 1/8" and may need a 1 1/4" that fits the brake booster. Tried to find one but is dificult for me to find the master cylinders internal specifications and interchangeability. I do need some help. Thanks 64Scout for your reply I think you are right.
Old Feb 19, 2023 | 12:26 AM
Gale Banks 80''s Avatar
Gale Banks 80'
Who cares about the Brakes congrats on getting over your health concerns ! But if you are still concerned about your Brakes so as to not get any new Health issues maybe describe just what Calipers it is that You are using ?
Old Feb 19, 2023 | 02:09 AM
ChumpVette's Avatar
ChumpVette
Sounds like the old AO Engineering kit.
Get a brake master for a 98-02 F-body. That will be enough fluid displacement to bring the pedal up. You will need to run a small spacer between the master and the booster.
Old Feb 19, 2023 | 12:15 PM
Rory Vega's Avatar
Rory Vega
7th Gear
Thaks ChumoVette fdor your reply. The kit is a BRK-X2 Dual Caliper Brake Assembly, must be similar. I do understand that the stock C4 master cylinder bore is one inch or 15/16". Trying to find a 98-02 F-Body master cylinder I have found a Dorman M630022 the bore is just a little bit less tha one inch. Found on ebay a Centric Parts 130.62072 brake master cylinder for a 98-02 Camaro Firebird with a 31.7mm bore= to 1.2480"=11/4", probably is something like this. Please let me know the brand and part referenceof a master cylinder that you know will fit without modifications and if it is possible tell me something about the spacer between the master and the booster too. Thanks a lot.
To C4 Automatic dual caliper brake assembly
