Ignition key question
Old Feb 28, 2023 | 08:49 AM
rberge12's Avatar
rberge12
Default Ignition key question
Hey yall,
I have a 92 vert with 1 ignition key. Id like another, so I determined (res test) I have #3 vats chip. I ordered a #3 from the "A" place and had it cut. I t works to turn the igninition to acc, but will not turn the cylinder to start. I guess I need a different blank #3 . are there certain keys just for vettes? Doing some looking, the key I purchased was 14.99. I see some that say corvette for around 56 on "flee bay"
Do I need to spring for the "corvette" one?
thanks
Old Feb 28, 2023 | 09:24 AM
WVZR-1's Avatar
WVZR-1
Does your key look like the one in this link with the resistor?
https://www.zoro.com/strattec-stratt...yABEgJ8sfD_BwE
If the mechanical cuts of the key are correct and the blank is correct it should rotate in both directions.
