Timing chain replacement question
Old Mar 9, 2023 | 11:41 AM
Thematt120's Avatar
Thematt120
Default Timing chain replacement question
In the middle of replacing a timing chain on an 88. I got all of the top engine pieces out of the way all the down to having the water pump out. I think the next step is removing the harmonic balancer and pulley(?)
How exactly do I remove these next parts ? I wasn’t sure if it would mess up the engine timing. I wanna be 100 percent sure of how to do it before I move onto it.
Old Mar 9, 2023 | 01:39 PM
FostersPerformance's Avatar
FostersPerformance
Remove, distributor, intake system, water pump, crank pulley, balancer (yes you need a tool), and oil pan to do this. If you didn't mark your timing, yes it will be off. And you will have to rotate engine to install and line up chain as well.
Old Mar 9, 2023 | 02:05 PM
SH-60B's Avatar
SH-60B
You remove the intake and dizzy just to change the chain?
Old Mar 9, 2023 | 02:21 PM
FostersPerformance
Yup I'm getting old. Thanks for pointing that out lol
Correction, dont remove intake and distributor.
Old Mar 9, 2023 | 05:56 PM
jseremba's Avatar
jseremba
Remove the timing chain cover and bring the engine around to where number one is firing. Pull the harmonic balancer. When you install the new chain. If the marks on the crank and cam are at twelve O'clock the engine is timed, kinda. If you but the cam mark at 6 and the crank mark at twelve the engine is 180 degrees out and number 6 is firing. This is not in the directions. I called the timing chain company and the CS rep said this is the mistake that most people make. I said why isn't it in the directions. He said they will not tell me, LoL
Don't forget you need to loosen the rocker arms and remove the lifters.
Old Mar 10, 2023 | 09:45 AM
SH-60B's Avatar
SH-60B
Line up the notch on the balancer with the 0 degree mark on the timing tab while feeling for compression in the #1 hole. That's TDC, go ahead and replace your timing components, making note of the position of the timing dots on the gears. Replace them in the same orientation. If it's just a timing set no need to remove lifters, unless your removing the cam
Old Mar 10, 2023 | 10:17 AM
jseremba's Avatar
jseremba
oops you are correct. I am thinking of replaciing the cam also. My bad.
Old Mar 10, 2023 | 11:21 AM
jazfe's Avatar
jazfe
Default Harmoic Balancer Removal
https://www.summitracing.com/parts/p...SABEgINrvD_BwE
You will need one of these.
You can piece together one of your own. I did but the time spent on research is hardly worth it. The tool is not expensive.
Old Mar 10, 2023 | 11:27 AM
jseremba's Avatar
jseremba
Auto Zone and Advanced Auto rent the harmonic balancer puller for free. All you do is leave a deposit. The harmonic balancer installer is only 25 bucks. So even if they do not have one to rent. They are cheap to buy
To Timing chain replacement question
